I have downloaded the zwave 1.8.0 snap shot and that is in the addons folder and also have downloaded and extracted the Habmin2-0.0.15-relase.zip into /opt/openhab/webapps
pi@raspberrypi /opt/openhab/webapps $ ls
assets HABmin2-0.0.15-release.zip images index.html languages README static
pi@raspberrypi /opt/openhab/addons $ ls
org.openhab.binding.mqtt-1.7.0.jar org.openhab.binding.xbmc-1.7.0.jar org.openhab.io.habmin-1.7.0-SNAPSHOT.jar
org.openhab.binding.wemo-1.7.0.jar org.openhab.binding.zwave-1.8.0-SNAPSHOT.jar
I am assuming that this should be placed in the addons directory ?
P.s is the below correct? I am using Habmin2-0.0.15-release.zip (obviously unzipped as shown below) with OH1 version of Habmin .jar (org.openhab.io.habmin-1.7.0-SNAPSHOT.jar)
You need to create a folder called habmin2 in /opt/openhab/webapps, unzip HABmin2-0.0.15-release.zip, put it in the folder /opt/openhab/webapps/habmin2, place the downloaded binding jar for version 1 of habmin in the addons folder, delete the version 2 binding addon of habmin and point your browser to http://192.168.1.80:8080/habmin2
BUT: I recommend to use habmin1 because habmin2 is targeted to OH 2.x, habmin 1 is a little bit easier to use and you can do all the necessary stuff with it for your z-wave nodes …
I have that same problem with Raspberry (OH 1.8). I have installed newest habmin on
/usr/share/openhab/webapps/habmin
addons
I get webpage of habmin, but I can’t see config, items, etc. It tells that OH is offline. Under port 8080, openhab works, but I understand that it use same port.
Service was restarted.
This shows [SOLVED] but i dont see a solution? I have the same setup oh1.8.2 and habmin1.7. I have the 1.7 binding in place and the habmin folder in webapps. But simply get 404
I also get a 404 when trying to access webapps/static/index.html (which exists) so i am wondering if it has something to do with my webapps folder all together…
