icompas
(Immo)
June 10, 2018, 3:12pm
1
I have a power button as follows:
<div class="icon backdrop" ng-class="{backdrop: backdrop, center: center, inline: inline}" style="width: 75%; height: 75%; margin: auto">
<img height="100%" ng-class="{ colorize: colorize }" class="icon-tile-backdrop ng-scope colorize" ng-src="/static/icons/pipes.svg" src="/static/icons/pipes.svg"></img>
</div>
<div class="widget" ng-if="itemValue('Pumpe_Warmwasser')=='OFF'" ng-click="sendCmd('Pumpe_Warmwasser', 'ON')">
<div class="power-off" ><svg width="36" height="36" viewBox="0 0 16 16"><use xlink:href="/static/icons/001-power-off.svg#Capa_1"></use></svg></div>
<div class="data_text">AUS</div>
</div>
<div class="widget" ng-if="itemValue('Pumpe_Warmwasser')=='ON'" ng-click="sendCmd('Pumpe_Warmwasser', 'OFF')">
<div class="power-on" ><svg width="36" height="36" viewBox="0 0 16 16"><use xlink:href="/static/icons/001-power-on.svg#Capa_1"></use></svg></div>
<div class="data_text">AN</div>
</div>
I moved my environment to a different server some weeks ago. A couple of days ago I updated the system to 2.3. Thus, I’m not sure if the mirgation caused to the new server caused the button to sop working, or the upgrade to 2.3.
I did not change any line of code, so I’m wondering what is wrong.
Anyone had a similar experience already?
opus
(Jürgen Baginski)
June 10, 2018, 3:25pm
2
Can’t say much about the code-lines, however did you copy the icons to the new server?
icompas
(Immo)
June 10, 2018, 3:27pm
3
The lines are from the new server. I actually re-imported them again. No change though.
icompas
(Immo)
June 11, 2018, 8:18am
4
Ok, found my issue.
The backdrop image needs to be within the button definition. That works.
<div ng-if="itemValue('Pumpe_Warmwasser')=='OFF'" >
<button class="btn bnt-lg"
style="background: transparent; font-size: 12px"
<div class="power-off" ><svg width="32" height="32" viewBox="0 0 16 16"><use xlink:href="/static/icons/001-power-on.svg#Capa_1"></use></svg></div>
<div class="icon backdrop" ng-class="{backdrop: backdrop, center: center, inline: inline}" style="width: 100%; height: 100%; margin: auto">
</div>
</button>
</div>
<div ng-if="itemValue('Pumpe_Warmwasser')=='ON'" >
<button class="btn btn-lg"
<div class="power-off" ><svg width="32" height="32" viewBox="0 0 16 16"><use xlink:href="/static/icons/001-power-off.svg#Capa_1"></use></svg></div>
</div>
</button>
</div>
