I am running “tip of the spear” build on a Pi3.
I have 4 EcoLink motion sensors which have worked for over a year with no problem. (and, Yes - I have replaced the batteries).
Sometime recently (cannot identify exactly when because I’m totally redoing my automation architecture…“film at 11:00” – so this was a relatively minor item initially—no longer minor though…)
The generic item descriptors for these sensors look like this:
Switch MO_u_01_MOTION_PIR34 "PIR34 KitchenMotionSensor [MAP(en.map):%s]" <shield> (gMotion,gKitchen,gMotion_u_01,gKitchen_u_01) { channel="zwave:device:8426aca6:node34:sensor_door" }
Switch MO_u_01_MOTION_PIR34_Alarm "PIR34 KitchenMotion Alarm [%s]" <shield> (gMotion,gKitchen,gMotion_u_01,gKitchen_u_01) { channel="zwave:device:8426aca6:node34:alarm_general" }
Number MO_u_01_MOTION_PIR34_Sensor_Battery "PIR34 Kitchen MotionSensor Battery [%d]" <energy> (BatteryLevels) { channel="zwave:device:8426aca6:node34:battery-level" }
( I also fiddled with sensor_binary vs sensor_door – there was no change in behavior after a “cold start”.)
The …Alarm and _Sensor_Battery items get triggered (evidenced by the event.log), but the main motion Switch does NOT show up in the event.log via it’s named item. It DOES show up as this:
2017-11-22 16:11:45.949 [vent.ItemStateChangedEvent] - zwave_device_8426aca6_node34_sensor_door changed from CLOSED to OPEN
2017-11-22 16:12:38.156 [vent.ItemStateChangedEvent] - MO_u_01_MOTION_PIR34_Alarm changed from NULL to ON
2017-11-22 16:12:47.774 [vent.ItemStateChangedEvent] - MO_u_01_MOTION_PIR34_Sensor_Battery changed from NULL to 100
Anyone have a clue ???
