Hello guys,
Has anyone managed to run HDL (BusPros) in OPENHAB2?
I tried https://github.com/andrey-desman/openhab-hdl without success.
Hello guys,
Anyone?
I have only used the 1.x binding. Tried it under 2.x as 1.x legacy without success. I think there was some issue initialization of network socket.
There are some Node.js and Node-red implementations here (haven’t had time to try it yet):
I have made a simple test with node-red-contrib-hdl.
The Dimmer Level value is input to the function node, where the required JSON object is build up. Like this:
var dim_level = Number(msg.payload);
msg.topic = "1.103"
msg.payload = {
code: 49,
data: {
channel: 6,
level: dim_level
return msg;
I can then manipulate a Dimmer Item in OpenHab, and use Node-Red to send that value to the HDL controller.
It worked. Thank you very much !
How to install this binding?
