2.992 DEBUG o.o.b.n.internal.NestActivator[:35]- Nest binding has been started. Version 1.10.0.201702080211
3.178 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[last_connection]
3.189 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=last_connection
3.223 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[last_connection]'
3.240 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[structures(Corby Street).name]
3.254 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=structures(Corby Street).name
3.260 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[structures(Corby Street).name]'
3.274 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[structures(Corby Street).country_code]
3.282 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=structures(Corby Street).country_code
3.295 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[structures(Corby Street).country_code]'
3.303 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[structures(Corby Street).postal_code]
3.313 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=structures(Corby Street).postal_code
3.317 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[structures(Corby Street).postal_code]'
3.325 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[structures(Corby Street).time_zone]
3.330 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=structures(Corby Street).time_zone
3.343 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[structures(Corby Street).time_zone]'
3.348 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[structures(Corby Street).away]
3.353 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=structures(Corby Street).away
3.364 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[structures(Corby Street).away]'
3.393 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[structures(Corby Street).structure_id]
3.397 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=structures(Corby Street).structure_id
3.401 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[structures(Corby Street).structure_id]'
3.415 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[structures(Corby Street).rhr_enrollment]
3.420 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=structures(Corby Street).rhr_enrollment
3.431 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[structures(Corby Street).rhr_enrollment]'
3.438 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).humidity]
3.443 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).humidity
3.449 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).humidity]'
3.460 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).locale]
3.475 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).locale
3.479 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).locale]'
3.490 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[thermostats(Dining Room).temperature_scale]
3.498 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).temperature_scale
3.504 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[thermostats(Dining Room).temperature_scale]'
3.513 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).is_using_emergency_heat]
3.522 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).is_using_emergency_heat
3.532 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).is_using_emergency_heat]'
3.545 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).has_fan]
3.554 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).has_fan
3.564 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).has_fan]'
3.573 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).software_version]
3.578 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).software_version
3.583 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).software_version]'
3.595 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).has_leaf]
3.603 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).has_leaf
3.608 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).has_leaf]'
3.618 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).device_id]
3.623 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).device_id
3.634 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).device_id]'
3.643 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).name]
3.653 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).name
3.658 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).name]'
3.663 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).can_heat]
3.683 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).can_heat
3.700 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).can_heat]'
3.707 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).can_cool]
3.732 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).can_cool
3.736 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).can_cool]'
3.743 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[thermostats(Dining Room).hvac_mode]
3.760 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).hvac_mode
3.767 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[thermostats(Dining Room).hvac_mode]'
3.783 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[thermostats(Dining Room).target_temperature_c]
3.793 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).target_temperature_c
3.803 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[thermostats(Dining Room).target_temperature_c]'
3.812 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[thermostats(Dining Room).target_temperature_f]
3.835 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).target_temperature_f
3.855 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[thermostats(Dining Room).target_temperature_f]'
3.862 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[thermostats(Dining Room).target_temperature_high_c]
3.875 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).target_temperature_high_c
3.884 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[thermostats(Dining Room).target_temperature_high_c]'
3.894 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[thermostats(Dining Room).target_temperature_high_f]
3.897 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).target_temperature_high_f
3.902 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[thermostats(Dining Room).target_temperature_high_f]'
3.907 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[thermostats(Dining Room).target_temperature_low_c]
3.911 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).target_temperature_low_c
3.915 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[thermostats(Dining Room).target_temperature_low_c]'
3.920 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[thermostats(Dining Room).target_temperature_low_f]
3.924 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).target_temperature_low_f
3.928 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[thermostats(Dining Room).target_temperature_low_f]'
3.932 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).ambient_temperature_c]
3.936 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).ambient_temperature_c
3.940 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).ambient_temperature_c]'
3.947 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).ambient_temperature_f]
3.951 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).ambient_temperature_f
3.955 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).ambient_temperature_f]'
3.959 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).eco_temperature_high_c]
3.964 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).eco_temperature_high_c
3.968 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).eco_temperature_high_c]'
3.972 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).eco_temperature_high_f]
3.976 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).eco_temperature_high_f
3.980 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).eco_temperature_high_f]'
3.985 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).eco_temperature_low_c]
3.989 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).eco_temperature_low_c
3.993 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).eco_temperature_low_c]'
4.007 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).eco_temperature_low_f]
4.011 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).eco_temperature_low_f
4.016 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).eco_temperature_low_f]'
4.030 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).away_temperature_high_c]
4.038 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).away_temperature_high_c
4.049 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).away_temperature_high_c]'
4.054 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).away_temperature_high_f]
4.063 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).away_temperature_high_f
4.888 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).away_temperature_high_f]'
4.893 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).away_temperature_low_c]
4.906 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).away_temperature_low_c
4.911 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).away_temperature_low_c]'
4.918 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).away_temperature_low_f]
4.922 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).away_temperature_low_f
4.926 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).away_temperature_low_f]'
4.930 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).structure_id]
4.934 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).structure_id
4.939 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).structure_id]'
4.943 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[thermostats(Dining Room).fan_timer_active]
4.947 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).fan_timer_active
4.951 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[thermostats(Dining Room).fan_timer_active]'
4.956 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).fan_timer_timeout]
4.959 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).fan_timer_timeout
4.963 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).fan_timer_timeout]'
4.968 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).name_long]
4.972 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).name_long
4.976 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).name_long]'
4.980 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).is_online]
4.993 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).is_online
4.998 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).is_online]'
5.002 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).last_connection]
5.006 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).last_connection
5.010 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).last_connection]'
5.015 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).hvac_state]
5.018 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).hvac_state
5.022 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).hvac_state]'
5.027 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).where_id]
5.031 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).where_id
5.035 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).where_id]'
5.039 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).is_locked]
5.043 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).is_locked
5.047 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).is_locked]'
5.051 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).locked_temp_min_f]
5.056 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).locked_temp_min_f
5.066 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).locked_temp_min_f]'
5.073 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).locked_temp_max_f]
5.077 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).locked_temp_max_f
5.081 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).locked_temp_max_f]'
5.086 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).locked_temp_min_c]
5.090 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).locked_temp_min_c
5.094 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).locked_temp_min_c]'
5.098 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).locked_temp_max_c]
5.102 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).locked_temp_max_c
5.106 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).locked_temp_max_c]'
5.113 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[thermostats(Dining Room).label]
5.117 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).label
5.121 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[thermostats(Dining Room).label]'
5.125 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).sunlight_correction_enabled]
5.129 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).sunlight_correction_enabled
5.133 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).sunlight_correction_enabled]'
5.142 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).sunlight_correction_active]
5.148 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).sunlight_correction_active
5.152 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).sunlight_correction_active]'
5.157 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).where_name]
5.164 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).where_name
5.169 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).where_name]'
5.174 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig==[thermostats(Dining Room).fan_timer_duration]
5.178 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).fan_timer_duration
5.181 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '=[thermostats(Dining Room).fan_timer_duration]'
5.186 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).time_to_target]
5.190 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).time_to_target
5.194 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).time_to_target]'
5.198 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).time_to_target_training]
5.202 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).time_to_target_training
5.206 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).time_to_target_training]'
5.210 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[thermostats(Dining Room).previous_hvac_mode]
5.216 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=thermostats(Dining Room).previous_hvac_mode
5.220 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[thermostats(Dining Room).previous_hvac_mode]'
5.224 TRACE o.o.b.n.i.NestGenericBindingProvider[:150]- validateItemType called with bindingConfig=<[structures(Corby Street).thermostats(Dining Room).ambient_temperature_f]
5.228 TRACE o.o.b.n.i.NestGenericBindingProvider[:160]- validateItemType called with property=structures(Corby Street).thermostats(Dining Room).ambient_temperature_f
5.232 DEBUG o.o.b.n.i.NestGenericBindingProvider[:112]- Processing binding configuration: '<[structures(Corby Street).thermostats(Dining Room).ambient_temperature_f]'
5.878 TRACE o.o.b.n.internal.NestBinding[:155]- Querying Nest API
8.235 TRACE o.o.b.n.i.m.AbstractRequest[:131]- About to execute 'https://developer-api.nest.com/?auth=xxxx'
0.648 TRACE o.o.b.n.i.m.AbstractRequest[:172]- {"devices":{"thermostats":{"VO89ixxxx":{"humidity":25,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false,"has_fan":true,"software_version":"5.6-7","has_leaf":false,"where_id":"lZIoJ-w1OAFAt7y93WE965-BygLAZQxniQmlJLXkZPaT1bLVAoCM4g","device_id":"VO89iU63InQKsbsFXmkF8wQggojwJ2yj","name":"Dining Room","can_heat":true,"can_cool":true,"target_temperature_c":24.0,"target_temperature_f":76,"target_temperature_high_c":25.0,"target_temperature_high_f":77,"target_temperature_low_c":22.0,"target_temperature_low_f":72,"ambient_temperature_c":24.5,"ambient_temperature_f":77,"away_temperature_high_c":28.5,"away_temperature_high_f":84,"away_temperature_low_c":21.0,"away_temperature_low_f":70,"eco_temperature_high_c":28.5,"eco_temperature_high_f":84,"eco_temperature_low_c":21.0,"eco_temperature_low_f":70,"is_locked":false,"locked_temp_min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0,"locked_temp_max_f":72,"sunlight_correction_active":false,"sunlight_correction_enabled":true,"structure_id":"oxCcYjkxUfr_V8BGW9LkkHaSinVx_u_QbJ0QMgE8PVOARrzbA3fQqQ","fan_timer_active":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":30,"previous_hvac_mode":"","hvac_mode":"heat","time_to_target":"~0","time_to_target_training":"ready","where_name":"Dining Room","label":"","name_long":"Dining Room Thermostat","is_online":true,"last_connection":"T21:53:46.072Z","hvac_state":"off"}}},"structures":{"oxCcYjkxUfr_xxx":{"name":"Corby Street ","country_code":"US","postal_code":"6xxxx","time_zone":"America/Chicago","away":"home","thermostats":["VO89iU63Ixxx"],"structure_id":"oxCcYjkxxx","rhr_enrollment":false,"eta_begin":"1970-01-01T00:00:00.000Z","wheres":{"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Backyard"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Basement"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxx","name":"Bedroom"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Den"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Dining Room"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Downstairs"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Driveway"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Entryway"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Family Room"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Front Yard"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Hallway"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Kids Room"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Kitchen"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Living Room"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Master Bedroom"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Office"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Outside"},"lZIoJ-xxxx":{"where_id":"lZIoJ-xxxx","name":"Upstairs"}}}},"metadata":{"access_token":"xxxx","client_version":1}}
4.405 TRACE o.o.b.n.internal.NestBinding[:195]- Retrieved data model: DataModelResponse[devices=DataModel.Devices[thermostats={VO89iU63InQKsbsFXmkF8wQggojwJ2yj=Thermostat[device_id=VO89iU63InQKsbsFXmkF8wQggojwJ2yj,name=Dining Room,locale=en-US,software_version=5.6-7,structure_id=oxCcYjkxUfr_V8BGW9LkkHaSinVx_u_QbJ0QMgE8PVOARrzbA3fQqQ,name=Dining Room,name_long=Dining Room Thermostat,last_connection=Fri Feb 10 15:53:46 CST 2017,is_online=true,where_id=lZIoJ-w1OAFAt7y93WE965-BygLAZQxniQmlJLXkZPaT1bLVAoCM4g,where_name=Dining Room,can_cool=true,can_heat=true,is_using_emergency_heat=false,has_fan=true,fan_timer_active=false,fan_timer_timeout=Wed Dec 31 18:00:00 CST 1969,has_leaf=false,temperature_scale=F,target_temperature_f=76,target_temperature_c=24.0,target_temperature_high_f=77,target_temperature_high_c=25.0,target_temperature_low_f=72,target_temperature_low_c=22.0,eco_temperature_high_f=84,eco_temperature_high_c=28.5,eco_temperature_low_f=70,eco_temperature_low_c=21.0,away_temperature_high_f=84,away_temperature_high_c=28.5,away_temperature_low_f=70,away_temperature_low_c=21.0,hvac_mode=heat,ambient_temperature_f=77,ambient_temperature_c=24.5,humidity=25,hvac_state=off,is_locked=false,locked_temp_min_f=68,locked_temp_max_f=72,locked_temp_min_c=20.0,locked_temp_max_c=22.0,label=,sunlight_correction_enabled=true,sunlight_correction_active=false,fan_timer_duration=30,time_to_target=~0,time_to_target_training=ready,previous_hvac_mode=]},smoke_co_alarms=<null>,cameras=<null>],structures={oxCcYjkxUfr_V8BGW9LkkHaSinVx_u_QbJ0QMgE8PVOARrzbA3fQqQ=Structure[structure_id=oxCcYjkxUfr_V8BGW9LkkHaSinVx_u_QbJ0QMgE8PVOARrzbA3fQqQ,thermostats=[VO89iU63InQKsbsFXmkF8wQggojwJ2yj],smoke_co_alarms=<null>,cameras=<null>,away=home,name=Corby Street ,country_code=US,postal_code=64501,peak_period_start_time=<null>,peak_period_end_time=<null>,time_zone=America/Chicago,eta=<null>,eta_begin=Wed Dec 31 18:00:00 CST 1969,rhr_enrollment=false,co_alarm_state=<null>,smoke_alarm_state=<null>]},error=<null>]
4.623 TRACE o.o.b.n.internal.NestBinding[:208]- Updating itemName 'NestTStat_software_version' with newState '5.6-7'
4.909 TRACE o.o.b.n.internal.NestBinding[:215]- Added event (item='NestTStat_software_version', newState='5.6-7') to the ignore event list (size=1)
4.924 TRACE o.o.b.n.internal.NestBinding[:208]- Updating itemName 'NestTStat_time_to_target' with newState '~0'
4.936 TRACE o.o.b.n.internal.NestBinding[:215]- Added event (item='NestTStat_time_to_target', newState='~0') to the ignore event list (size=2)
4.964 TRACE o.o.b.n.internal.NestBinding[:208]- Updating itemName 'NestTStat_where_id' with newState 'lZIoJ-xxxx'
4.968 TRACE o.o.b.n.internal.NestBinding[:215]- Added event (item='NestTStat_where_id', newState='lZIoJ-xxxx') to the ignore event list (size=3)
4.985 TRACE o.o.b.n.internal.NestBinding[:208]- Updating itemName 'NestTStat_sunlight_correction_enabled' with newState 'ON'
4.988 TRACE o.o.b.n.internal.NestBinding[:215]- Added event (item='NestTStat_sunlight_correction_enabled', newState='ON') to the ignore event list (size=4)
4.993 TRACE o.o.b.n.internal.NestBinding[:208]- Updating itemName 'NestTStat_time_to_target_training' with newState 'ready'
5.013 TRACE o.o.b.n.internal.NestBinding[:215]- Added event (item='NestTStat_time_to_target_training', newState='ready') to the ignore event list (size=5)
5.024 TRACE o.o.b.n.internal.NestBinding[:208]- Updating itemName 'NestTStat_is_locked' with newState 'OFF'
5.028 TRACE o.o.b.n.internal.NestBinding[:215]- Added event (item='NestTStat_is_locked', newState='OFF') to the ignore event list (size=6)
5.812 TRACE o.o.b.n.internal.NestBinding[:299]- Received update (item='NestTStat_software_version', state='5.6-7')
5.824 DEBUG o.o.b.n.internal.NestBinding[:321]- We received this event (item='NestTStat_software_version', state='5.6-7') from Nest, so we don't send it back again -> ignore!
5.835 ERROR o.o.b.n.internal.NestBinding[:240]- Unable to get state from data model
org.apache.commons.beanutils.NestedNullException: Null property value for 'structures(Corby Street).away' on bean class 'class org.openhab.binding.nest.internal.messages.DataModelResponse'
at org.apache.commons.beanutils.PropertyUtilsBean.getNestedProperty(PropertyUtilsBean.java:755)
at org.apache.commons.beanutils.PropertyUtilsBean.getProperty(PropertyUtilsBean.java:846)
at org.openhab.binding.nest.internal.messages.DataModel.getProperty(DataModel.java:353)
at org.openhab.binding.nest.internal.NestBinding.getState(NestBinding.java:238)
at org.openhab.binding.nest.internal.NestBinding.readNest(NestBinding.java:206)
at org.openhab.binding.nest.internal.NestBinding.execute(NestBinding.java:168)
Havent figure out how to get around character limit…
