wondering if someone could help me with what should just be simple. i have a ‘string item’ containing json data like this:
{“contact”:true,“linkquality”:47,“battery”:91,“voltage”:2985}
String door_sensor_01_json "JSON String" {channel="mqtt:topic:door_sensor_01:json"}
so then i have a rule that splits out the json into individual ‘number’ items:
rule "Convert JSON to individual values"
Item door_sensor_01_json changed
// use the transformation service to retrieve the value
val battery = transform("JSONPATH", "$.battery", door_sensor_01_json.state.toString)
val linkquality = transform("JSONPATH", "$.linkquality", door_sensor_01_json.state.toString)
val voltage = transform("JSONPATH", "$.voltage", door_sensor_01_json.state.toString)
val contact = transform("JSONPATH", "$.contact", door_sensor_01_json.state.toString)
// post the new value to the Number Item
door_sensor_01_battery.postUpdate( battery )
door_sensor_01_linkquality.postUpdate( linkquality )
door_sensor_01_voltage.postUpdate( voltage )
// door_sensor_01_contact.postUpdate( contact )
this all works and the items get the values.
Now what i would like is to be able to divide the ‘voltage’ by 1000 before doing the postUpdate - and this is where i’m failing miserably!
i’ve tried various combinations of things but just keep getting errors in the log. i’m thinking that ‘voltage’ is a string that i need to convert first before doing maths on it? - but then why does it postUpdate to a ‘Number’ item?
can anyone give me any pointers please?
