First things first:
Use code fences when publishing code
Second, while loops and Thread:sleep inside rules are bad ideas (Especially a while loop with a Thread::sleep inside it!!)
Use this:
//// !!!!! There three variable declaration go AT THE TOP of the rules file !!!!!
var Timer sleepTimer = null // timer variable
var percent = 100 // global variable so the timer lamdba can access it
var color = 10 // global variable so the timer lamdba can access it
rule "Go to sleep"
Item Scene_Slaapkamer changed to 9
//Go from from a bright orang-red to soft red (and off)
logInfo("GoToSleep", "Starting", Scene_Slaapkamer.state.toString)
ColorSlaapkamer.sendCommand("10,100,100")
percent = 100
color = 10
// No need to check if the scene number is 9 because that was the rule trigger
if (sleepTimer === null) { //If there is no timer
sleepTimer = createTimer(now(), [ | // then create one to start immediately
ColorSlaapkamer.sendCommand(color.toString + ",100," + percent.toString)
color = percent / 10
percent = percent - 5
logInfo("GoToSleep", color.toString, percent.toString)
if (percent > 0) { // if the light is still ON then run the timer again in 30s
sleepTimer.reshedule(now.plusSeconds(30))
else { // if the percent has reached 0 then we cancel the timer and turn off the light
sleepTimer = null
SwSlaapkamer.sendCommand(OFF)
Scene_Slaapkamer.sendCommand(0)
logInfo("GoToSleep", "Finshed ")
