I’m struggling with a rule where I need your help with:
Aim: Turn water on for 2 min/5min, depending on a setpoint item ( vRegnerDauer
) in the sitemap, turn off for 30sec and repeat this 4 times.
The 30sec is done via the expire binding, using a dummy switch (Beregnung_Timer30s
The pump itself is controlled via a plug (item eg_az_l_stecker1)
var Timer TimerBeregnung = null
rule "Beregnung an"
Item test_rainbird changed to ON or
Item Beregnung_Timer30s changed from ON to OFF
val Dauer = (vRegnerDauer.state as DecimalType).intValue
if(!(BeregnungsCounter.state instanceof Number)){
BeregnungsCounter.postUpdate(1)
} // Initializing the counter if NULL
if(BeregnungsCounter.state > 4 ){
} // reset of Counters if >4
logInfo("Beregnung", "Phase " + BeregnungsCounter.state + " startet")
if(BeregnungsCounter.state <= 4 && BeregnungsCounter.state >=1){
BeregnungsCounter.postUpdate(1+(BeregnungsCounter.state as Number))
} // count repetitive watering
if( BeregnungsCounter.state >= 1 && BeregnungsCounter.state <= 4 ) {
TimerBeregnung = createTimer(now.plusMinutes(vRegnerDauer)) [|
eg_az_l_stecker1.sendCommand(ON)]
if( BeregnungsCounter.state <= 3 ) {
Beregnung_Timer30s.sendCommand(ON)
} else {
test_rainbird.sendCommand(OFF)
logInfo("Beregnung", "Alle 4 Beregnungsphasen beendet")
This to turn off the pump:
rule "Beregnung aus"
when Item Beregnung_Timer30s changed from OFF to ON
eg_az_l_stecker1.sendCommand(OFF)
What’s wrong with my logic here?
Error log:
2018-06-22 08:27:09.545 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Beregnung an':
An error occurred during the script execution:
Could not invoke method: org.joda.time.DateTime.plusMinutes(int) on instance: 2018-06-22T08:27:09.542+02:00
Kurt
