When I try to use the remote heater action, I get the same error. But the pre-climatization action works for me. If you lookup the details in PaperUI for the Thing, you see the list of supported and not supported channels/actions.
@noppes123 & @kjoglums, Thanks a lot for your help. I got it running based on the rule example of @kjoglums. For me it works as follows (via Alexa Voice command):
rule "VOC Heater On"
Item Volvo_Standheizung_Alexa changed to ON
val actions = getActions("volvooncall", "volvooncall:vehicle:YV*************")
if(actions===null) {
logWarn("VOC", "Actions not Found")
return
else {
logWarn("Volvo", "VOC - Actions")
actions.preclimatizationStartCommand()
Volvo_Standheizung_Alexa.sendCommand(OFF)
The only thing is, that I can start the Preclimatization but cannot stop it. I assume I still have to modify the code a bit here for a correct stop command.
Yes, I have tried it with the preclimatizationStopCommand() but it doesnāt work. It is not a drama for me, as Iām happy that I can at least start the heater Being able also to stop it would be great but thatās no problem so far. By the way: by using the starting command preclimatizationStartCommand()without a number in the brackets, the heater will run to its maximum operation time and will then stop automatically, correct?
I havenĀ“t used the preclimatizationStopCommand() either, as the preclimatizationStartCommand() will run similar as if you were to run āHeat Startā from VOC App. Meaning, as you say, the heater will only run to its maximum operation time. Also, the heat commands will not queue if you were to give the command more than once, as this will only generate an immediate error response from the Volvo API itself (if an existing command is ongoing), and the additional command will be cancelled.
Similar as if you try to run heating from app with too little remaining fuel (at least for my V90 Ā“18 diesel), OH will not force the heater to start. So I havenĀ“t found any real benefits/needs and practical use for the preclimatizationStopCommand()
Thatās correct. With the changes in the PR you can start/stop de preclimatization with a switch in OH.
It also works in combination with the app, FE: start with OH, stop with the app and vice versa.
Dear all,
unfortunately my VOC setup doesnāt work anymore. So far it has been working well. Currently I get the following error messages in openhab.log. Does anybody have an idea about the reason and how to solve the problem?
2020-04-24 11:33:45.416 [ERROR] [nternal.items.ItemStateConverterImpl] - A conversion of null was requested:
java.lang.IllegalArgumentException: State must not be null.
at org.eclipse.smarthome.core.internal.items.ItemStateConverterImpl.convertToAcceptedState(ItemStateConverterImpl.java:58) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.sendUpdate(ProfileCallbackImpl.java:134) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onStateUpdateFromHandler(SystemDefaultProfile.java:53) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.lambda$9(CommunicationManager.java:467) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.lambda$11(CommunicationManager.java:487) ~[?:?]
at java.lang.Iterable.forEach(Iterable.java:75) ~[?:1.8.0_232]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.handleCallFromHandler(CommunicationManager.java:483) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.stateUpdated(CommunicationManager.java:465) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$1.stateUpdated(ThingManagerImpl.java:168) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateState(BaseThingHandler.java:245) ~[?:?]
at org.openhab.binding.volvooncall.internal.handler.VehicleHandler.lambda$6(VehicleHandler.java:164) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183) ~[?:1.8.0_232]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:175) ~[?:1.8.0_232]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193) ~[?:1.8.0_232]
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382) ~[?:1.8.0_232]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:482) ~[?:1.8.0_232]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:472) ~[?:1.8.0_232]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) ~[?:1.8.0_232]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) ~[?:1.8.0_232]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:1.8.0_232]
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:485) ~[?:1.8.0_232]
at org.openhab.binding.volvooncall.internal.handler.VehicleHandler.queryApiAndUpdateChannels(VehicleHandler.java:161) ~[?:?]
at org.openhab.binding.volvooncall.internal.handler.VehicleHandler.handleCommand(VehicleHandler.java:211) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.channelLinked(BaseThingHandler.java:191) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:267) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_232]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_232]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_232]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
Iām having trouble understanding the other # carEvent function ā¦
When I test from Postman, I cannot access this resource.
I am developing a script for recording intermediate GPS coordinates in order to plot the routes on a Leaflet map.
At the beginning I based myself on EngineRunning but it is inoperative ā¦
The notion of trigger would be saving for me.
