Hi everyone
Its time too trim down my persistence logging
when i first set it up i just logged every change for all items just too get it up and running this is no longer needed.
I would like too only log certain items now how do i add these items too the config file i looked at the docs but coulden’t work out what needed too do all the items need to be logged every 1 min
I’m still not super confident using groups the few times i have tried i have had mixed results (I do have a couple of groups that i use that work ok)
it is something i plan on doing at some point after moving all my items over to text files i started with paper ui so changing items is a bit of a pain
Thanks for your quick replys and help on this i will mark as solved once i change my file
Move your items to text files, you will find that it’s easier in the long run
Also you can configure you items just the way you want and it’s far more flexible than the UI.
Have a go, break things, enjoy!
I have already moved a few over to text i needed too so i could use the google home binding
when i first setup i didnt use a single text file but soon found that ui rules were extremely limited i now plan on moving everything too text my rules already are text just items and things
i have no idea how too add a text thing atm i will learn soon enough
