Hi guys,
I would really appreciate some guidance regarding this simple rule:
//Systemair_Virkningsgrad//
rule "systemair virkningsgrad prosent"
Time cron "0 0/1 * * * ?" // every minute
if ( Systemair_Heater_Status.state == OFF) {
logInfo("Systemair", "Virkningsgrad rule triggered")
var Number virkningsgrad = ((Systemair_Supply_temp.state as Number) - (Systemair_Outdoor_temp.state as Number) / (Systemair_Extract_temp.state as Number) - (Systemair_Outdoor_temp.state as Number) * 100)
logInfo("test", "Systemair Tilluft-Temp = " + (Systemair_Supply_temp.state as Number))
logInfo("test", "Systemair Utendørs-Temp = " + (Systemair_Outdoor_temp.state as Number))
logInfo("test", "Systemair Avtrekks-Temp = " + (Systemair_Extract_temp.state as Number))
Systemair_Virkningsgrad.sendCommand(virkningsgrad)
Log results:
2018-10-10 20:01:15.402 [INFO ] [pse.smarthome.model.script.Systemair] - Virkningsgrad rule triggered
2018-10-10 20:01:15.428 [INFO ] [.eclipse.smarthome.model.script.test] - Systemair Supply-Temp = 21.5
2018-10-10 20:01:15.436 [INFO ] [.eclipse.smarthome.model.script.test] - Systemair Utend�rs-Temp = 13.2
2018-10-10 20:01:15.444 [INFO ] [.eclipse.smarthome.model.script.test] - Systemair Avtrekks-Temp = 24.7
2018-10-10 20:01:15.458 [ome.event.ItemCommandEvent] - Item 'Systemair_Virkningsgrad' received command -1299.03441296
2018-10-10 20:01:15.472 [vent.ItemStateChangedEvent] - Systemair_Virkningsgrad changed from NULL to -1299.03441296
What is wrong with my matemathics in “val Number virkningsgrad”?
Christian
