That’s the one, I knew there was a REGEX that was pooling the whole string.
I never use REGEX, I just can get my head around it…
Let me understand.
With Feed Binding I can extrapolate the “description” part in an item like:
String MeteoAlarm_description {channel="feed:feed:meteoalarm:description"}
Then I need a rule that can parse what I need in that string? can you please explain a bit more?
thanks
Andrea
No, the rule you need only, if you use this way
String s "s[%s]" {http="<[https://www.scanmatic.no/vaeret-i-kilsund/:60000:REGEX((.*?))]"}
Thanks @hr3
Interesting, it seems working
if for example I try to parse
https://www.meteoalarm.eu/en_UK/1/0/EE002-Estonia.html
via https://regex101.com/
with this REGEX:
.*aw.*?([0-9]+[0-9]+).*.
I see two numbers (what I want):
53
82
Question is: how to manage the array when I have 2+ alerts? At this moment in time if I have 2 alerts, I can see only the last one.
thanks
Andrea
the first idea I have is definitely not elegant:
- create 12 items for all 12 alerts (aw1x, aw2x, … where x is the level of criticity) and put all 12 items in one group “meteoalarms”
- play with visibility in sitemap to see only the alerts I have in my region
any other suggestion how to play with array in regex?
Andrea
Hi Vincent,
Would you mind helping out some more?
I struggle a bit with the wind direction parsing. It has got both number and text value in the same separator line,
so it get overwritten with the wrong value.
2018-08-05 20:27:46.453 [ome.event.ItemCommandEvent] - Item 'Kilsund_Vindretning' received command NV
2018-08-05 20:27:46.526 [vent.ItemStateChangedEvent] - Kilsund_Vindretning changed from to 1
I’m just interessted in the text value, in this Case “NV” for NorthWest.
Do you have any solutions for me on this matter?
BR
Christian
Two html nodes in series
And the function node contains:
msg.payload = msg.payload[0];
return msg;
Thank you Vincent. But that doesn’t give me any output at all :S Does this work for you?
thx
Christian
It works for me. It’s the same http request node as before.
hmmm… Is this how your HTML node looks like?
I changed to “HTML content of the element” and now its working Thanks again Vincent!
Sorry I couldn’t reply. My broadband Internet is down. I am replying from my phone.
Glad you got it sorted
