I agree, since others here in this thread managed to fix the problem by using a different software for configuring the device.
According to the manual, this device should have a report group value equal to the sum of all parameters that we need to be reported. Setting this to 0 means report nothing.
If the device is anything like itās predecessors, which I am quite certain it is, at least one report group needs to be populated to receive reports.
Unfortunately this doesnāt have a the update of the groups. The binding wonāt update anything if it hasnāt changed, so youād need to change it and then change it back.
According to the database, there is only the lifeline in the ZW095 and the manual confirms this. I guess weāre talking about a different entry - can we be clear what version etc weāre talking about.
The log provided also only seems to show a single group,
Automatic REPORTs come from the HEM will be sent via single-cast to associated devices in association group 1.
What kind of reports need to be sent that can be configured via Configuration Command Class (see
below section).
My suspicion here is that this is an MCA issue so I want to see what commands are being sent to configure the associations (hence the need for the log). Iād also like to get the XML for this device so I can find out what command class versions are reported.
I am mistaken then. The predecessors (non-Plus) have 3 report groups. I never looked at the association section of the manual for the gen5 meter. The manual does refer to report groups 1-3, so I assumed there were association groups for them like the older devices have.
as I said some posts before I also have that issues with the device.
I followed the recent suggestions.
Attached my log, where I set report group 1 to 0 and after some seconds back to my value I want reported which is 2097152
It still does not send any reports on the defined intervall of 5 secs.
If only send the wanted report on a refresh on on the polling period.
I already watched the log with chris log-viewer and can see something that looks strange to me.
The last command send shows a config request with a value of 8192 but I never set such a value, so why is that send. Could that be the issues or part of it ?
Can provide more logs, just tell me what you need.
I donāt see any association groups being configured in this log
Thanks. I would like to see what happens when you configure associations.
This appears to just be a display issue. You have set the value 0x020000 - the log viewer is just displaying this incorrectly. You can see this in the log.
No - thatās not the case. Firstly, thereās only one group, and the groups are not changing - in the log, the only group that I see being āupdatedā is this line -:
There are 3 params called report group and there is a single association group.
I updated the report groups, and I think you needed to see the log for the association group.
No - this is wrong for the device being discussed as per the title on this thread.
There is only 1 association group on the ZW095 in the database, and the documentation confirms this. My guess is you may have an older version so it might pay for you to specify what you actually have.
