I bought a CCU3 with 6 radiator thermostat and I do not get ONLINE in the Openhab.
Openhab: 2.3.0
CCU3: 3.51.6
I read the Homematic binding docs and the forum, and I do not get working. I used the PaperUI to set it up.
I putted special attention into the “Configure Farewall” and “Security”, then in the Thing I set it up manually with the IP because in the inbox does not detect nothing.
I am missing something?
Thanks,
2020-02-22 08:34:19.080 [ERROR] [matic.handler.HomematicBridgeHandler] - Homematic bridge was set to OFFLINE-COMMUNICATION_ERROR due to the following exception: java.net.NoRouteToHostException: No route to host
java.io.IOException: java.net.NoRouteToHostException: No route to host
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.sendMessage(XmlRpcClient.java:94) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.sendMessage(XmlRpcClient.java:98) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.sendMessage(XmlRpcClient.java:63) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.getDeviceDescription(RpcClient.java:122) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.getGatewayInfo(RpcClient.java:220) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.HomematicGatewayFactory.loadGatewayInfo(HomematicGatewayFactory.java:47) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.HomematicGatewayFactory.createGateway(HomematicGatewayFactory.java:31) ~[?:?]
at org.openhab.binding.homematic.handler.HomematicBridgeHandler.lambda$0(HomematicBridgeHandler.java:85) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: java.util.concurrent.ExecutionException: java.net.NoRouteToHostException: No route to host
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:110) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:676) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.sendMessage(XmlRpcClient.java:80) ~[?:?]
... 14 more
Caused by: java.net.NoRouteToHostException: No route to host
at sun.nio.ch.SocketChannelImpl.checkConnect(Native Method) ~[?:?]
at sun.nio.ch.SocketChannelImpl.finishConnect(SocketChannelImpl.java:717) ~[?:?]
at org.eclipse.jetty.io.SelectorManager.finishConnect(SelectorManager.java:355) ~[?:?]
at org.eclipse.jetty.io.ManagedSelector.processConnect(ManagedSelector.java:352) ~[?:?]
at org.eclipse.jetty.io.ManagedSelector.access$900(ManagedSelector.java:56) ~[?:?]
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.processSelected(ManagedSelector.java:289) ~[?:?]
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.produce(ManagedSelector.java:181) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:249) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) ~[?:?]
... 1 more
