Hi
running openHAB version 1.8.0 on Raspberry Pi 2 Model B (raspbian jessie)
Trying binding to HomeMatic CCU1 (Firmware 1.519)
Homematic binding is running into a read time out. After that even the Homematic CCU1 is frozen with no response from homematic web UI.
attached the openhab log file with homemativ binding in TRACE mode:
2016-01-17 11:18:29.027 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.0).
2016-01-17 11:18:33.821 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-01-17 11:18:34.014 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2016-01-17 11:18:42.335 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'default.sitemap’
2016-01-17 11:18:43.082 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'kili.sitemap’
2016-01-17 11:18:43.382 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'logging.persist’
2016-01-17 11:18:43.509 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'db4o.persist’
2016-01-17 11:18:43.537 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'mysql.persist’
2016-01-17 11:18:43.561 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'exec.persist’
2016-01-17 11:18:43.576 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist’
2016-01-17 11:18:43.602 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2016-01-17 11:18:44.185 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'default.items’
2016-01-17 11:18:44.284 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'kili.items’
2016-01-17 11:18:49.591 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /classicui/openhab.app
2016-01-17 11:18:55.272 [DEBUG] [o.b.h.i.bus.HomematicActivator] - Homematic binding has been started.
2016-01-17 11:18:55.428 [DEBUG] [omematicGenericBindingProvider] - Adding item Temp_OUT with DatapointConfig[address=JEQ0149196,channel=1,parameter=TEMPERATURE]
2016-01-17 11:18:55.432 [DEBUG] [omematicGenericBindingProvider] - Adding item Temp_WZ with DatapointConfig[address=HEQ0509056,channel=1,parameter=TEMPERATURE]
2016-01-17 11:18:55.435 [DEBUG] [omematicGenericBindingProvider] - Adding item Temp_SZ with DatapointConfig[address=IEQ0151523,channel=1,parameter=TEMPERATURE]
2016-01-17 11:18:55.438 [DEBUG] [omematicGenericBindingProvider] - Adding item Temp_ZO with DatapointConfig[address=IEQ0150704,channel=1,parameter=TEMPERATURE]
2016-01-17 11:18:55.441 [DEBUG] [omematicGenericBindingProvider] - Adding item Temp_ZU with DatapointConfig[address=IEQ0151203,channel=1,parameter=TEMPERATURE]
2016-01-17 11:18:55.444 [DEBUG] [omematicGenericBindingProvider] - Adding item Temp_BAD with DatapointConfig[address=IEQ0151370,channel=1,parameter=TEMPERATURE]
2016-01-17 11:18:55.447 [DEBUG] [omematicGenericBindingProvider] - Adding item Hum_OUT with DatapointConfig[address=JEQ0149196,channel=1,parameter=HUMIDITY]
2016-01-17 11:18:55.450 [DEBUG] [omematicGenericBindingProvider] - Adding item Hum_WZ with DatapointConfig[address=HEQ0509056,channel=1,parameter=HUMIDITY]
2016-01-17 11:18:55.453 [DEBUG] [omematicGenericBindingProvider] - Adding item Hum_SZ with DatapointConfig[address=IEQ0151523,channel=1,parameter=HUMIDITY]
2016-01-17 11:18:55.457 [DEBUG] [omematicGenericBindingProvider] - Adding item Hum_ZO with DatapointConfig[address=IEQ0150704,channel=1,parameter=HUMIDITY]
2016-01-17 11:18:55.460 [DEBUG] [omematicGenericBindingProvider] - Adding item Hum_ZU with DatapointConfig[address=IEQ0151203,channel=1,parameter=HUMIDITY]
2016-01-17 11:18:55.463 [DEBUG] [omematicGenericBindingProvider] - Adding item Hum_BAD with DatapointConfig[address=IEQ0151370,channel=1,parameter=HUMIDITY]
2016-01-17 11:18:55.466 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_Licht1 with DatapointConfig[address=IEQ0006232,channel=1,parameter=STATE]
2016-01-17 11:18:55.469 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_Licht2 with DatapointConfig[address=IEQ0007194,channel=1,parameter=STATE]
2016-01-17 11:18:55.472 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_TV with DatapointConfig[address=IEQ0074628,channel=1,parameter=STATE]
2016-01-17 11:18:55.475 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_TVALL with DatapointConfig[address=IEQ0378017,channel=1,parameter=STATE]
2016-01-17 11:18:55.478 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_ROUTER with DatapointConfig[address=IEQ0074589,channel=1,parameter=STATE]
2016-01-17 11:18:55.481 [DEBUG] [omematicGenericBindingProvider] - Adding item ZO_TV with DatapointConfig[address=IEQ0378018,channel=1,parameter=STATE]
2016-01-17 11:18:55.484 [DEBUG] [omematicGenericBindingProvider] - Adding item BU_DRUCK with DatapointConfig[address=IEQ0521979,channel=1,parameter=STATE]
2016-01-17 11:18:55.487 [DEBUG] [omematicGenericBindingProvider] - Adding item PC_UG with DatapointConfig[address=IEQ0522021,channel=1,parameter=STATE]
2016-01-17 11:18:55.490 [DEBUG] [omematicGenericBindingProvider] - Adding item Heizung_ZU with DatapointConfig[address=IEQ0151203,channel=2,parameter=SETPOINT]
2016-01-17 11:18:55.493 [DEBUG] [omematicGenericBindingProvider] - Adding item Heizung_WZ with DatapointConfig[address=HEQ0509056,channel=2,parameter=SETPOINT]
2016-01-17 11:18:55.496 [DEBUG] [omematicGenericBindingProvider] - Adding item Heizung_ZO with DatapointConfig[address=IEQ0150704,channel=2,parameter=SETPOINT]
2016-01-17 11:18:55.499 [DEBUG] [omematicGenericBindingProvider] - Adding item Heizung_BAD with DatapointConfig[address=IEQ0151370,channel=2,parameter=SETPOINT]
2016-01-17 11:18:55.502 [DEBUG] [omematicGenericBindingProvider] - Adding item Heizung_SZ with DatapointConfig[address=IEQ0151523,channel=2,parameter=SETPOINT]
2016-01-17 11:18:55.505 [DEBUG] [omematicGenericBindingProvider] - Adding item BUR_Fen with DatapointConfig[address=IEQ0032375,channel=1,parameter=STATE]
2016-01-17 11:18:55.508 [DEBUG] [omematicGenericBindingProvider] - Adding item ZU_Fen with DatapointConfig[address=HEQ0364148,channel=1,parameter=STATE]
2016-01-17 11:18:55.511 [DEBUG] [omematicGenericBindingProvider] - Adding item ZU1_Tuer with DatapointConfig[address=HEQ0363827,channel=1,parameter=STATE]
2016-01-17 11:18:55.513 [DEBUG] [omematicGenericBindingProvider] - Adding item ZU2_Tuer with DatapointConfig[address=IEQ0029091,channel=1,parameter=STATE]
2016-01-17 11:18:55.515 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_Tuer with DatapointConfig[address=IEQ0029545,channel=1,parameter=STATE]
2016-01-17 11:18:55.518 [DEBUG] [omematicGenericBindingProvider] - Adding item GWC_Fen with DatapointConfig[address=HEQ0363480,channel=1,parameter=STATE]
2016-01-17 11:18:55.521 [DEBUG] [omematicGenericBindingProvider] - Adding item Haus_Tuer with DatapointConfig[address=HEQ0364025,channel=1,parameter=STATE]
2016-01-17 11:18:55.523 [DEBUG] [omematicGenericBindingProvider] - Adding item KUC_Fen with DatapointConfig[address=HEQ0363098,channel=1,parameter=STATE]
2016-01-17 11:18:55.527 [DEBUG] [omematicGenericBindingProvider] - Adding item BAD_Tuer with DatapointConfig[address=HEQ0363250,channel=1,parameter=STATE]
2016-01-17 11:18:55.529 [DEBUG] [omematicGenericBindingProvider] - Adding item BAD_Fen with DatapointConfig[address=HEQ0363022,channel=1,parameter=STATE]
2016-01-17 11:18:55.532 [DEBUG] [omematicGenericBindingProvider] - Adding item SZ_Fen with DatapointConfig[address=HEQ0363467,channel=1,parameter=STATE]
2016-01-17 11:18:55.535 [DEBUG] [omematicGenericBindingProvider] - Adding item ZO1_Fen with DatapointConfig[address=IEQ0032538,channel=1,parameter=STATE]
2016-01-17 11:18:55.538 [DEBUG] [omematicGenericBindingProvider] - Adding item ZO2_Fen with DatapointConfig[address=HEQ0362998,channel=1,parameter=STATE]
2016-01-17 11:18:55.540 [DEBUG] [omematicGenericBindingProvider] - Adding item AL_Wasser with DatapointConfig[address=HEQ0031687,channel=1,parameter=STATE]
2016-01-17 11:18:55.543 [DEBUG] [omematicGenericBindingProvider] - Adding item AL_Rauch1 with DatapointConfig[address=IEQ0011996,channel=1,parameter=STATE]
2016-01-17 11:18:55.545 [DEBUG] [omematicGenericBindingProvider] - Adding item AL_Rauch2 with DatapointConfig[address=IEQ0011492,channel=1,parameter=STATE]
2016-01-17 11:18:55.548 [DEBUG] [omematicGenericBindingProvider] - Adding item AL_Rauch3 with DatapointConfig[address=IEQ0011388,channel=1,parameter=STATE]
2016-01-17 11:18:55.550 [DEBUG] [omematicGenericBindingProvider] - Adding item AL_Rauch with DatapointConfig[address=IEQ0011492,channel=1,parameter=STATE]
2016-01-17 11:18:55.553 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_Licht_aus with DatapointConfig[address=HEQ0403380,channel=1,parameter=PRESS_SHORT]
2016-01-17 11:18:55.556 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_Licht_an with DatapointConfig[address=HEQ0403380,channel=2,parameter=PRESS_SHORT]
2016-01-17 11:18:55.559 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_AutoL_aus with DatapointConfig[address=HEQ0403380,channel=1,parameter=PRESS_LONG]
2016-01-17 11:18:55.562 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_AutoL_an with DatapointConfig[address=HEQ0403380,channel=2,parameter=PRESS_LONG]
2016-01-17 11:18:55.565 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_TV_aus with DatapointConfig[address=HEQ0403380,channel=3,parameter=PRESS_SHORT]
2016-01-17 11:18:55.568 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_TV_an with DatapointConfig[address=HEQ0403380,channel=4,parameter=PRESS_SHORT]
2016-01-17 11:18:55.571 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_TV_All with DatapointConfig[address=HEQ0403380,channel=3,parameter=PRESS_LONG]
2016-01-17 11:18:55.574 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_PC_aus with DatapointConfig[address=HEQ0403380,channel=5,parameter=PRESS_SHORT]
2016-01-17 11:18:55.577 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_PC_an with DatapointConfig[address=HEQ0403380,channel=6,parameter=PRESS_SHORT]
2016-01-17 11:18:55.579 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_Party_aus with DatapointConfig[address=HEQ0403380,channel=9,parameter=PRESS_SHORT]
2016-01-17 11:18:55.582 [DEBUG] [omematicGenericBindingProvider] - Adding item WZ_Party_an with DatapointConfig[address=HEQ0403380,channel=1,parameter=PRESS_SHORT]
2016-01-17 11:18:55.585 [DEBUG] [omematicGenericBindingProvider] - Adding item Abwesend with DatapointConfig[address=HEQ0403380,channel=9,parameter=PRESS_LONG]
2016-01-17 11:18:55.592 [DEBUG] [omematicGenericBindingProvider] - Adding item Anwesend with DatapointConfig[address=HEQ0403380,channel=10,parameter=PRESS_LONG]
2016-01-17 11:18:55.598 [DEBUG] [omematicGenericBindingProvider] - Adding item Reload_Variables with DatapointConfig[address=BidCoS-RF,channel=40,parameter=PRESS_SHORT,action=RELOAD_VARIABLES]
2016-01-17 11:18:55.602 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Fenster_offen with VariableConfig[name=VAR: Fenster offen]
2016-01-17 11:18:55.604 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Fenster_Schlafzimmer with VariableConfig[name=VAR: Fenster Schlafzimmer]
2016-01-17 11:18:55.606 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Fenster_Wohnzimmer with VariableConfig[name=VAR: Fenster Wohnzimmer]
2016-01-17 11:18:55.608 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Fenster_Zimmer_oben with VariableConfig[name=VAR: Fenster Zimmer oben]
2016-01-17 11:18:55.611 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Fenster_Zimmer_unten with VariableConfig[name=VAR: Fenster Zimmer unten]
2016-01-17 11:18:55.614 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Fenster_Bad with VariableConfig[name=VAR: Fenster Bad]
2016-01-17 11:18:55.616 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Tageszeit with VariableConfig[name=VAR: Tageszeit]
2016-01-17 11:18:55.618 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Feiertag with VariableConfig[name=VAR: Feiertag]
2016-01-17 11:18:55.620 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Heizung with VariableConfig[name=VAR: Heizung]
2016-01-17 11:18:55.622 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Hzg_Idx with VariableConfig[name=VAR: Heizung]
2016-01-17 11:18:55.625 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_HzgTemp_WZ with VariableConfig[name=VAR: HzgTemp WZ]
2016-01-17 11:18:55.627 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Licht_an with VariableConfig[name=VAR: Licht an]
2016-01-17 11:18:55.629 [DEBUG] [omematicGenericBindingProvider] - Adding item VAR_Auto_Licht with VariableConfig[name=VAR: Auto Licht]
2016-01-17 11:18:55.631 [DEBUG] [omematicGenericBindingProvider] - Adding item ALR_Batterie_schwach with VariableConfig[name=ALR: Batterie schwach]
2016-01-17 11:18:55.633 [DEBUG] [omematicGenericBindingProvider] - Adding item ALR_Einbruch with VariableConfig[name=ALR: Einbruch]
2016-01-17 11:18:55.635 [DEBUG] [omematicGenericBindingProvider] - Adding item ALR_Rauch_Alarm with VariableConfig[name=ALR: Rauch Alarm]
2016-01-17 11:18:55.637 [DEBUG] [omematicGenericBindingProvider] - Adding item ALR_Stromausfall with VariableConfig[name=ALR: Stromausfall]
2016-01-17 11:18:55.639 [DEBUG] [omematicGenericBindingProvider] - Adding item ALR_Wasser_Alarm with VariableConfig[name=ALR: Wasser Alarm]
2016-01-17 11:18:55.642 [DEBUG] [omematicGenericBindingProvider] - Adding item PRG_Anwesend with ProgramConfig[name=PRG: Anwesend]
2016-01-17 11:18:55.645 [DEBUG] [omematicGenericBindingProvider] - Adding item PRG_Abwesend with ProgramConfig[name=PRG: Abwesend]
2016-01-17 11:18:55.647 [DEBUG] [omematicGenericBindingProvider] - Adding item PRG_Alles_Strom_aus with ProgramConfig[name=PRG: Alles Strom aus]
2016-01-17 11:18:55.649 [DEBUG] [omematicGenericBindingProvider] - Adding item PRG_Auto_Licht_aus with ProgramConfig[name=PRG: Auto Licht aus]
2016-01-17 11:18:55.650 [DEBUG] [omematicGenericBindingProvider] - Adding item PRG_Auto_Licht_ein with ProgramConfig[name=PRG: Auto Licht ein]
2016-01-17 11:18:55.652 [DEBUG] [omematicGenericBindingProvider] - Adding item PRG_Batterie_Status with ProgramConfig[name=PRG: Batterie Status]
2016-01-17 11:18:55.654 [DEBUG] [omematicGenericBindingProvider] - Adding item PRG_Comming_Home with ProgramConfig[name=PRG: Comming Home]
2016-01-17 11:18:55.656 [DEBUG] [omematicGenericBindingProvider] - Adding item PRG_Licht_WZ_an with ProgramConfig[name=PRG: Licht WZ an]
2016-01-17 11:18:55.659 [DEBUG] [omematicGenericBindingProvider] - Adding item PRG_Licht_WZ_aus with ProgramConfig[name=PRG: Licht WZ aus]
2016-01-17 11:18:55.661 [DEBUG] [omematicGenericBindingProvider] - Adding item PRG_Party_off with ProgramConfig[name=PRG: Party off]
2016-01-17 11:18:55.664 [DEBUG] [omematicGenericBindingProvider] - Adding item PRG_Party_on with ProgramConfig[name=PRG: Party on]
2016-01-17 11:18:55.759 [INFO ] [o.o.b.h.i.bus.HomematicBinding] - HomematicConfig[host=192.168.0.160,timeout=15,callbackHost=192.168.0.40,callbackPort=9123,aliveInterval=300,reconnectInterval=disabled]
2016-01-17 11:18:55.761 [INFO ] [.b.h.i.c.HomematicCommunicator] - Starting Homematic communicator
2016-01-17 11:18:55.771 [DEBUG] [.h.i.communicator.ItemDisabler] - Starting ItemDisabler
2016-01-17 11:18:55.799 [TRACE] [.o.b.h.i.c.client.BinRpcClient] - Client BinRpcRequest BinRpcRequest[methodName=getDeviceDescription,args={BidCoS-RF}]
2016-01-17 11:18:55.836 [INFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
2016-01-17 11:18:55.857 [TRACE] [.o.b.h.i.c.client.BinRpcClient] - Client BinRpcResponse: {
ADDRESS=BidCoS-RF
CHILDREN=
BidCoS-RF:0
BidCoS-RF:1
BidCoS-RF:2
BidCoS-RF:3
BidCoS-RF:4
BidCoS-RF:5
BidCoS-RF:6
BidCoS-RF:7
BidCoS-RF:8
BidCoS-RF:9
BidCoS-RF:10
BidCoS-RF:11
BidCoS-RF:12
BidCoS-RF:13
BidCoS-RF:14
BidCoS-RF:15
BidCoS-RF:16
BidCoS-RF:17
BidCoS-RF:18
BidCoS-RF:19
BidCoS-RF:20
BidCoS-RF:21
BidCoS-RF:22
BidCoS-RF:23
BidCoS-RF:24
BidCoS-RF:25
BidCoS-RF:26
BidCoS-RF:27
BidCoS-RF:28
BidCoS-RF:29
BidCoS-RF:30
BidCoS-RF:31
BidCoS-RF:32
BidCoS-RF:33
BidCoS-RF:34
BidCoS-RF:35
BidCoS-RF:36
BidCoS-RF:37
BidCoS-RF:38
BidCoS-RF:39
BidCoS-RF:40
BidCoS-RF:41
BidCoS-RF:42
BidCoS-RF:43
BidCoS-RF:44
BidCoS-RF:45
BidCoS-RF:46
BidCoS-RF:47
BidCoS-RF:48
BidCoS-RF:49
BidCoS-RF:50
FIRMWARE=1.519
FLAGS=9
INTERFACE=IEQ0005797
PARAMSETS=
MASTER
PARENT=
RF_ADDRESS=1366841
ROAMING=0
TYPE=HM-RCV-50
VERSION=6
2016-01-17 11:18:55.863 [INFO ] [.b.h.i.c.HomematicCommunicator] - Homematic ServerId[name=CCU,version=1.519,address=IEQ0005797]
2016-01-17 11:18:55.881 [INFO ] [o.o.b.h.i.c.client.CcuClient ] - Starting CcuClient
2016-01-17 11:18:55.883 [DEBUG] [.o.b.h.i.c.client.BinRpcClient] - Starting BinRpcClient
2016-01-17 11:18:55.985 [INFO ] [.p.rrd4j.internal.RRD4jService] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = [] 0 items(s) = []
2016-01-17 11:18:56.056 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic datapoints
2016-01-17 11:18:56.076 [TRACE] [o.o.b.h.i.c.client.CcuClient ] - TclRegaScript: string dev_id;
string channel_id;
string dp_id;
string extraDatapoints = “BOOT\tWORKING\tDIRECTION\tINSTALL_TEST\tPRESS_LONG_RELEASE\t”;
extraDatapoints = extraDatapoints # “PRESS_CONT\tHUMIDITYF\tLAST_TICKS\tUNITSPTURN\t”;
string extraDatapointName;
Write(’<?xml version="1.0" encoding="ISO-8859-1" standalone="yes"?>\n’);
Write("\n");
foreach (dev_id, root.Devices().EnumUsedIDs()) {
object dev_obj = dom.GetObject(dev_id);
string dev_interface= dev_obj.Interface();
string interface_name = dom.GetObject(dev_interface).Name();
boolean is_ready = dev_obj.ReadyConfig();
boolean isChannelFourPartyDevice = (dev_obj.HssType() == “HM-CC-RT-DN”) || (dev_obj.HssType() == “HM-CC-RT-DN-BoM”);
boolean isChannelTwoPartyDevice = (dev_obj.HssType() == “HM-TC-IT-WM-W-EU”);
boolean isSmokeDevice = (dev_obj.HssType() == “HM-Sec-SD”);
if(is_ready &&
(dev_obj.HssType() != “HMW-RCV-50”)) {
Write(" <device");
Write(" address='"); WriteXML(dev_obj.Address());
Write("' interface='"); WriteXML(interface_name);
Write("' type='"); WriteXML(dev_obj.HssType());
Write("'>\n");
foreach(channel_id, dev_obj.Channels()) {
object channel_obj = dom.GetObject(channel_id);
string channel_number = channel_obj.Address().StrValueByIndex(":",1).ToString();
boolean isChannelFour = channel_number == "4";
boolean isChannelTwo = channel_number == "2";
boolean isChannelOne = channel_number == "1";
Write(" <channel");
Write(" number='"); WriteXML(channel_number);
Write("'>\n");
foreach (extraDatapointName, extraDatapoints) {
object edp = channel_obj.DPByHssDP(extraDatapointName);
if (edp) {
Write(" <datapoint");
Write(" name='" # extraDatapointName);
Write("' value='");
if (edp.ValueType() == 2) {
Write("false");
else {
WriteXML(edp.Value());
Write("' valueType='" # edp.ValueType());
if (edp.ValueType() == 16) {
Write("' subType='"); WriteXML(edp.ValueSubType());
Write("' valueList='" # edp.ValueList());
if ((edp.ValueType() != 2) && (edp.ValueType() != 20)) {
Write("' min='" # edp.ValueMin());
Write("' max='" # edp.ValueMax());
Write("' writeable='false'");
Write(" />\n");
foreach(dp_id, channel_obj.DPs().EnumUsedIDs()) {
object dp_obj = dom.GetObject(dp_id);
if(dp_obj) {
string name = dp_obj.Name().StrValueByIndex(".",2);
if (name != "") {
Write(" name='"); WriteXML(name);
Write("' value='"); WriteXML(dp_obj.Value());
Write("' valueType='" # dp_obj.ValueType());
if (dp_obj.ValueType() == 16) {
Write("' subType='"); WriteXML(dp_obj.ValueSubType());
Write("' valueList='" # dp_obj.ValueList());
if ((dp_obj.ValueType() != 2) && (dp_obj.ValueType() != 20)) {
Write("' min='" # dp_obj.ValueMin());
Write("' max='" # dp_obj.ValueMax());
Write("' writeable='");
integer dp_operations = dp_obj.Operations();
boolean writeable = dp_operations & OPERATION_WRITE;
if (writeable) {
Write("true");
else {
Write("false");
Write("' />\n");
if ((isChannelFour && isChannelFourPartyDevice) || (isChannelTwo && isChannelTwoPartyDevice)) {
Write(" <datapoint name='PARTY_TEMPERATURE' value='5.0' valueType='4' min='5.0' max='30.0' writeable='true' />\n");
Write(" <datapoint name='PARTY_START_TIME' value='0' valueType='8' min='0' max='1410' writeable='true' />\n");
Write(" <datapoint name='PARTY_START_DAY' value='1' valueType='8' min='1' max='31' writeable='true' />\n");
Write(" <datapoint name='PARTY_START_MONTH' value='1' valueType='8' min='1' max='12' writeable='true' />\n");
Write(" <datapoint name='PARTY_START_YEAR' value='12' valueType='8' min='0' max='99' writeable='true' />\n");
Write(" <datapoint name='PARTY_STOP_TIME' value='0' valueType='8' min='0' max='1410' writeable='true' />\n");
Write(" <datapoint name='PARTY_STOP_DAY' value='1' valueType='8' min='1' max='31' writeable='true' />\n");
Write(" <datapoint name='PARTY_STOP_MONTH' value='1' valueType='8' min='1' max='12' writeable='true' />\n");
Write(" <datapoint name='PARTY_STOP_YEAR' value='12' valueType='8' min='0' max='99' writeable='true' />\n");
if (isChannelOne && isSmokeDevice) {
Write(" <datapoint name='STATE' value='false' valueType='2' writeable='false' />\n");
Write(" </channel>\n");
Write(" </device>\n");
Write("");
2016-01-17 11:18:57.447 [INFO ] [.myopenhab.internal.MyOHClient] - Connected to my.openHAB service (UUID = XXXXX, local base URL = http://localhost:8080)
2016-01-17 11:18:58.573 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Malvenstr1’.
2016-01-17 11:18:58.579 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Untergeschoss’.
2016-01-17 11:18:58.585 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Erdgeschoss’.
2016-01-17 11:18:58.595 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Obergeschoss’.
2016-01-17 11:18:58.602 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Aussen’.
2016-01-17 11:18:58.607 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Schalter’.
2016-01-17 11:18:58.612 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Klima’.
2016-01-17 11:18:58.618 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Heizung’.
2016-01-17 11:18:58.623 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Licht’.
2016-01-17 11:18:58.629 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Status’.
2016-01-17 11:18:58.652 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Phone’.
2016-01-17 11:18:58.696 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Alarm’.
2016-01-17 11:18:58.702 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Test’.
2016-01-17 11:18:58.707 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Variable’.
2016-01-17 11:18:58.732 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Temperatur’.
2016-01-17 11:18:58.737 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘Feuchtigkeit’.
2016-01-17 11:18:58.744 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘EG_Wohn’.
2016-01-17 11:18:59.074 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘UG_Keller’.
2016-01-17 11:18:59.080 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘UG_Buero’.
2016-01-17 11:18:59.102 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘UG_Kind’.
2016-01-17 11:18:59.118 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘OG_Schlaf’.
2016-01-17 11:18:59.123 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘OG_Bad’.
2016-01-17 11:18:59.131 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘OG_Kind’.
2016-01-17 11:18:59.136 [ERROR] [.p.m.i.MysqlPersistenceService] - mySQL: Unable to find table for query ‘A_Garten’.
2016-01-17 11:19:11.508 [ERROR] [.b.h.i.c.HomematicCommunicator] - Could not start Homematic communicator: Read timed out
org.openhab.binding.homematic.internal.communicator.client.HomematicClientException: Read timed out
at org.openhab.binding.homematic.internal.communicator.client.CcuClient.sendScript(CcuClient.java:322) ~[bundlefile:na]
at org.openhab.binding.homematic.internal.communicator.client.CcuClient.sendScriptByName(CcuClient.java:254) ~[bundlefile:na]
at org.openhab.binding.homematic.internal.communicator.client.CcuClient.iterateAllDatapoints(CcuClient.java:126) ~[bundlefile:na]
at org.openhab.binding.homematic.internal.communicator.StateHolder.loadDatapoints(StateHolder.java:84) ~[bundlefile:na]
at org.openhab.binding.homematic.internal.communicator.HomematicCommunicator.start(HomematicCommunicator.java:93) ~[bundlefile:na]
at org.openhab.binding.homematic.internal.bus.HomematicBinding.updated(HomematicBinding.java:95) [bundlefile:na]
at org.eclipse.equinox.internal.cm.ManagedServiceTracker$1.run(ManagedServiceTracker.java:183) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
at org.eclipse.equinox.internal.cm.SerializedTaskQueue$1.run(SerializedTaskQueue.java:36) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
Caused by: java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method) ~[na:1.8.0]
at java.net.SocketInputStream.read(SocketInputStream.java:150) ~[na:1.8.0]
at java.net.SocketInputStream.read(SocketInputStream.java:121) ~[na:1.8.0]
at java.io.BufferedInputStream.fill(BufferedInputStream.java:246) ~[na:1.8.0]
at java.io.BufferedInputStream.read(BufferedInputStream.java:265) ~[na:1.8.0]
at org.apache.commons.httpclient.HttpParser.readRawLine(HttpParser.java:78) ~[org.apache.commons.httpclient_3.1.0.v201012070820.jar:na]
at org.apache.commons.httpclient.HttpParser.readLine(HttpParser.java:106) ~[org.apache.commons.httpclient_3.1.0.v201012070820.jar:na]
at org.apache.commons.httpclient.HttpConnection.readLine(HttpConnection.java:1116) ~[org.apache.commons.httpclient_3.1.0.v201012070820.jar:na]
at org.apache.commons.httpclient.HttpMethodBase.readStatusLine(HttpMethodBase.java:1973) ~[org.apache.commons.httpclient_3.1.0.v201012070820.jar:na]
at org.apache.commons.httpclient.HttpMethodBase.readResponse(HttpMethodBase.java:1735) ~[org.apache.commons.httpclient_3.1.0.v201012070820.jar:na]
at org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1098) ~[org.apache.commons.httpclient_3.1.0.v201012070820.jar:na]
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398) ~[org.apache.commons.httpclient_3.1.0.v201012070820.jar:na]
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) ~[org.apache.commons.httpclient_3.1.0.v201012070820.jar:na]
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) ~[org.apache.commons.httpclient_3.1.0.v201012070820.jar:na]
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323) ~[org.apache.commons.httpclient_3.1.0.v201012070820.jar:na]
at org.openhab.binding.homematic.internal.communicator.client.CcuClient.sendScript(CcuClient.java:310) ~[bundlefile:na]
… 7 common frames omitted
2016-01-17 11:19:11.513 [INFO ] [.b.h.i.c.HomematicCommunicator] - Shutting down Homematic communicator
2016-01-17 11:19:11.515 [DEBUG] [b.h.i.c.s.BinRpcCallbackServer] - Shutting down BinRpcCallbackServer
2016-01-17 11:19:11.517 [TRACE] [.o.b.h.i.c.client.BinRpcClient] - Client BinRpcRequest BinRpcRequest[methodName=init,args={binary://192.168.0.40:9123}]
2016-01-17 11:19:11.524 [TRACE] [.o.b.h.i.c.client.BinRpcClient] - Client BinRpcResponse:
2016-01-17 11:19:11.526 [TRACE] [.o.b.h.i.c.client.BinRpcClient] - Client BinRpcRequest BinRpcRequest[methodName=init,args={binary://192.168.0.40:9123}]
2016-01-17 11:19:11.533 [TRACE] [.o.b.h.i.c.client.BinRpcClient] - Client BinRpcResponse:
2016-01-17 11:19:11.535 [TRACE] [.o.b.h.i.c.client.BinRpcClient] - Client BinRpcRequest BinRpcRequest[methodName=init,args={binary://192.168.0.40:9123}]
2016-01-17 11:19:11.539 [INFO ] [.o.b.h.i.c.client.BinRpcClient] - Interface CUxD not available, disabling support.
2016-01-17 11:19:11.540 [DEBUG] [.h.i.communicator.ItemDisabler] - Stopping ItemDisabler
2016-01-17 11:19:11.545 [INFO ] [.service.AbstractActiveService] - Homematic server connection tracker has been started
2016-01-17 11:19:11.660 [INFO ] [.service.AbstractActiveService] - NTP Refresh Service has been started
2016-01-17 11:19:14.659 [WARN ] [.b.h.i.c.HomematicCommunicator] - Can’t find DatapointConfig[address=IEQ0032538,channel=1,parameter=STATE], value is not published to openHAB!
2016-01-17 11:19:14.661 [WARN ] [.b.h.i.c.HomematicCommunicator] - Can’t find DatapointConfig[address=HEQ0403380,channel=2,parameter=PRESS_SHORT], value is not published to openHAB!
2016-01-17 11:19:14.663 [WARN ] [.b.h.i.c.HomematicCommunicator] - Can’t find DatapointConfig[address=IEQ0151523,channel=1,parameter=HUMIDITY], value is not published to openHAB!
2016-01-17 11:19:14.664 [WARN ] [.b.h.i.c.HomematicCommunicator] - Can’t find DatapointConfig[address=HEQ0509056,channel=1,parameter=HUMIDITY], value is not published to openHAB!
