I haven’t found anything regarding this issue, so I post it here:
I installed the Homematic HmIP-MOD-TM (Garage Door Module).
Trying to initialize the correspondent thing leads to the following error message:
HANDLER_CONFIGURATION_PENDING
{HMP_1_EVENT_DELAY_UNIT=Der Wert 1 ist nicht in den erlaubten Optionen enthalten. Erlaubte Optionen sind: [ParameterOption [value="100MS", label="100ms"], ParameterOption [value="S", label="seconds"], ParameterOption [value="M", label="minutes"], ParameterOption [value="H", label="hours"]], HMP_2_EVENT_RANDOMTIME_UNIT=Der Wert 1 ist nicht in den erlaubten Optionen enthalten. Erlaubte Optionen sind: [ParameterOption [value="100MS", label="100ms"], ParameterOption [value="S", label="seconds"], ParameterOption [value="M", label="minutes"], ParameterOption [value="H", label="hours"]], HMP_1_EVENT_RANDOMTIME_UNIT=Der Wert 1 ist nicht in den erlaubten Optionen enthalten. Erlaubte Optionen sind: [ParameterOption [value="100MS", label="100ms"], ParameterOption [value="S", label="seconds"], ParameterOption [value="M", label="minutes"], ParameterOption [value="H", label="hours"]], HMP_2_EVENT_DELAY_UNIT=Der Wert 1 ist nicht in den erlaubten Optionen enthalten. Erlaubte Optionen sind: [ParameterOption [value="100MS", label="100ms"], ParameterOption [value="S", label="seconds"], ParameterOption [value="M", label="minutes"], ParameterOption [value="H", label="hours"]]}
I am using OpenHAB 3.4 on a Raspi 4, Homematic CCU2 and the binding version is
org.openhab.binding.homematic-3.2.0-SNAPSHOT.jar
in my addons folder, which might be outdated.
Maybe someone can give me a hint, if there is an updated version of the homematic binding, which does not show this error.
