Yesterday I installed the Snapshot 2.2.0.20171010, after the Installation my homematic Binding didn’t work - with the Snapshot a week befor I have no Problems.
In the Homematic Binding the CCU2 IP address is correct, the Hometatic-Bridge is online but all homematic things are offline
Any Ideas ?
2017-10-11 04:36:37.805 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.29.22,address=MEQ1608886,wired=false,hmip=true,cuxd=false,group=true]
2017-10-11 04:36:38.042 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqttbroker’
2017-10-11 04:36:39.027 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-10-11 04:36:39.564 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-10-11 04:36:50.586 [ERROR] [very.HomematicDeviceDiscoveryService] - org/eclipse/smarthome/core/thing/type/ThingTypeBuilder
java.lang.NoClassDefFoundError: org/eclipse/smarthome/core/thing/type/ThingTypeBuilder
at org.openhab.binding.homematic.internal.type.HomematicTypeGeneratorImpl.createThingType(HomematicTypeGeneratorImpl.java:223) ~[197:org.openhab.binding.homematic:2.2.0.201710101453]
at org.openhab.binding.homematic.internal.type.HomematicTypeGeneratorImpl.generate(HomematicTypeGeneratorImpl.java:161) ~[197:org.openhab.binding.homematic:2.2.0.201710101453]
at org.openhab.binding.homematic.handler.HomematicBridgeHandler.onDeviceLoaded(HomematicBridgeHandler.java:280) ~[197:org.openhab.binding.homematic:2.2.0.201710101453]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.loadAllDeviceMetadata(AbstractHomematicGateway.java:380) ~[197:org.openhab.binding.homematic:2.2.0.201710101453]
at org.openhab.binding.homematic.internal.discovery.HomematicDeviceDiscoveryService$1.run(HomematicDeviceDiscoveryService.java:101) [197:org.openhab.binding.homematic:2.2.0.201710101453]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: java.lang.ClassNotFoundException: org.eclipse.smarthome.core.thing.type.ThingTypeBuilder cannot be found by org.openhab.binding.homematic_2.2.0.201710101453
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
… 12 more
2017-10-11 04:37:09.756 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule ‘Min Max Temperatur’: cannot invoke method public abstract org.eclipse.smarthome.core.types.State org.eclipse.smarthome.core.persistence.HistoricItem.getState() on null
2017-10-11 04:45:00.251 [WARN ] [ematic.handler.HomematicThingHandler] - Device with address ‘MEQ0727673’ not found on gateway ‘c464508c’
