- Platform information:
- Hardware: Raspberry PI 3
- OS: raspbian
- openHAB version: 2.2 (I guess)
- Issue of the topic: I want to manage an open Window Contact for my heating
- Please post configurations (if applicable):
- Items configuration related to the issue
// Buero
String maxModeBuero "Modus" <max_mode> (gMaxBuero, gMaxMode, gMaxAutoMode) {channel="max:thermostat:NEQ0101554:NEQ0100856:mode"}
Number maxSetTempBuero "Zieltemperatur [%.1f °C]" <max_temp> (gMaxBuero, gMaxSetTemp, gMaxAutoTemp) ["TargetTemperature"] {channel="max:thermostat:NEQ0101554:NEQ0100856:set_temp"}
Number maxActualTempBuero "Raumtemperatur [%.1f °C]" <max_temp> (gMaxBuero, gMaxActualTemp) ["CurrentTemperature"] {channel="max:thermostat:NEQ0101554:NEQ0100856:actual_temp"}
Switch maxBatLowBuero "Batteriestatus Büro [MAP(max.map):%s]" <battery> (gMaxBuero, gMaxBatLow) {channel="max:thermostat:NEQ0101554:NEQ0100856:battery_low"}
Number maxValveBuero "Ventilstellung [%d %%]" <max_valve> (gMaxBuero, gMaxValve) {channel="max:thermostat:NEQ0101554:NEQ0100856:valve"}
// Contact maxLockedBuero "Bediensperre [MAP(max.map):%s]" <lock> (gMaxBuero, gMaxLock) {channel="max:thermostat:NEQ0101554:NEQ0100856:locked"}
Contact maxWindowBuero "Fenster Büro [MAP(max.map):%s]" <window> (gMaxBuero, gMaxWindow) {channel="max:shuttercontact:NEQ0101554:NEQ0100259:contact_state"}
- Rules code related to the issue
val Number BueroTemp = 12.0
rule "Büro Fenster öffnen/schließen"
Item maxWindowBuero changed
if (maxWindowBuero.state == OPEN){
BueroTemp.sendCommand(maxSetTempBuero.set_temp)
// BueroTemp.postUpdate(maxSetTempBuero.set_temp) <- this I tried also
maxSetTempBuero.sendCommand(5.0)
if (maxWindowBuero.state == CLOSED){
maxSetTempBuero.sendCommand(BueroTemp)
- If logs where generated please post these here using code fences:
2018-01-28 20:01:04.429 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Büro Fenster öffnen/schließen': 'sendCommand' is not a member of 'java.lang.Double'; line 64, column 2, length 47
or
2018-01-28 19:54:04.276 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Büro Fenster öffnen/schließen': 'postUpdate' is not a member of 'java.lang.Double'; line 64, column 2, length 46
How can I save the current setting of my heating maxSetTempBuero?
I tried a lot of combinations but did not get the rule running.
I copied it from here:
Any help for a beginner is wellcome!
Thanks in advance,
Ralf
