I’m using OH2 on a Raspberry Pi and using rules to debug my rules.
I’m trying to pass the contents of a variable into the log file but it’s not working as expected:
When I push a ‘test’ switch a rule triggers and records a log entry, absolutely fine. But when I try to add a variable, the response does not include the variable.
logInfo("default.rules", "At Home state is: %1$", At_home.state )
The entry in the log is:
2018-06-22 20:52:32.544 [INFO ] [smarthome.model.script.default.rules] - At Home state is: %1$
I thought the %1$ would cause it to report the variable. Have I got something wrong, or does this imply a configuration error somewhere?
To explain, the logInfo wants to report a single string. Alpoy’s suggestion builds a string from your text fragment and the Item state.
Note that a .state isn’t necessarily a string, but OH will try to convert as well as it can. Sometimes you’ll need to be explicit, myItem.state.toString
As logInfo needs <string>, <string>, the correct command would be either
logInfo("default.rules", "At Home state is: " + At_home.state.toString)
or
logInfo("default.rules", "At Home state is: {}", At_home.state)
where {} is substituted with the value At_home.state. Pay attention to the fact, that no .toString is necessary.
It’s even possible to use more than one substitution:
