Dear All,
I have installed OpenHAB following the Linux installation way (well escpecially the RPi way which in short points to the Linux way):
https://www.openhab.org/docs/installation/linux.html
However I’m now missing the usual openhabian-config tool and some of the openhabian default installation stuff like frontail.
I also found an old topic with the same question:
https://community.openhab.org/t/solved-howto-add-config-tool-when-installed-by-package-repository-installation-method/44641
I apologies for opening a new thread but I hope as this is not marked as solved I will get an answer here.
In the mentioned topic someone recommended to additionally install openhabian through manual way (if I understood correctly).
But in this case what exactly happenes?
- Will the “Manual Installation” overwrite the repo based instance?
- Will it install only the differentials extending the Linux installation with openhabian capabilities?
- Or will it install another independent OpenHAB instance?
- Anything else?
Thank you in advance!
