Will appreciate if someone can point me to how to add application tile to the start dashboard. I want to add Grafana tile.
Thx!
Thx!
You need to create a files called: dashboard.cfg in your /services
folder
Then put this in the file:
grafana.link-name=Grafana
grafana.link-url=http://192.168.0.12:3000
grafana.link-imageurl=../static/grafana.png
You also need to add an image for the tile in your /html
I use this one:
Thank you!! It worked perfectly.
I did this BTW: (so IP is same as OpenHAB & not hardcoded)
grafana.link-url=http://{HOSTNAME}:3000/login
grafana.link-imageurl=…/static/grafana.png
