This is my first question here. I have configured a SDM-630 watt metter and an EP-SOLAR charge controller over paper UI
Now im trying to configure a Modbus Relay board.After 2 days trying to configure it over Paper UI, i stucked at a point of the transformations.
I can read the relays state, i can turn it on by the switch on Paper UI but, it dont turn of in the switch
I have read many tutorials and infos here about modbus binding, but really dont understand. Maybe my english is not enough for that task. I speak portuguese.
My question is: HOW TO CONFIGURE that board to turn on-off with Paper UI ?
Umm, we don’t know. What board, cannot see it from here?
It would be a really good idea to share what you have done so far, especially as it works in part.
It would be an even better idea to share any documentation you have about the relay board, i.e. what is it expecting you to send to turn on relays?
My goal is to deviate solar panels from my ON GRID inverters to my charging string.
in brazil, they are not paying good for the net metered energy, soo i started a lithium power wall, conected to an EPEVER TRACER AN controller. i want to use NODE-RED LATER to process the inputs from the SDM630 WATTMETER, and them deviate panels from ongrid to charging string using this relay board.
I already started constructing the node-red flow i can compare the wattage passing thru SDM 630 on each phase and then make something. this make something is turning on and off some panels of the ON GRID string.
Okay. So what you want is to have an openHAB Switch type Item, and when that is commanded ON or OFF you want to send 256 or 512 to a modbus holding register?
the only thing i see is the lack of documents explaining how to do it over PAPER UI. Maybe i will try to cooperate on that. everything here is using paper UI.
Hi guys!
I’m new to the forum and a bit of a novice. I am trying to configure a 32-relay shield but without success. I do it all for Paper UI.
The problem I have is that I cannot create the poller without a communication error. The error is:
COMMUNICATION_ERROR
Error with read: org.openhab.core.io.transport.modbus.internal.ModbusSlaveIOExceptionImpl: Modbus IO Error with cause = ModbusIOException, EOF = false, message = ‘I / O failed to write’, cause2 = null
I have tried to change the type (coil, discrete, holding and input) but without result.
I have done tests with another controller (similar to OH) and I have gotten it to work with the FC6 function. All I have to do is send the value 511 or 512.
Then that’s what you need to reproduce in openHAB.
Are you using the same details in your Modbus serial bridge?
Device wanting FC3/FC6 functions tells us that you’d want to use holding type in your poller Thing.
The note says we can read from start address 1 length 16
The note says the on/off state will be returned as 0001/0000 which is ordinary enough.
So you can set up 16 data Things, and link their switch channels to Switch type Items without any bother.
Then we can look at writing.
For each data Thing we add some write details - holding type, same address.
We want to use FC06 and that should happen by default.
But you need to send special data, not 0001/0000.
That’s described in post above
you’ll need to have MAP transformation installed.
If you have trouble, show us your Things using <code> tab, screenshots are not as helpful.
