I can’t find this anywhere and I’m suffering from the nightly heal issue.
Thanks!
Thanks!
You will find the configuration in HABmin: Go to the configuration , selevt “Things”, select your ZWave controller and look for the “Z-Wave Network Heal” entry. Select “Disabled” instead of a time when the network heal should take place and do not forget to store your configuration change
D’oh! I knew it was a simple fix but it was making me nuts trying to find it.
Thanks!
Please also try the latest snapshot to see if the problem still occurs.
did you change anything substantial about the heal after 2.5.1, is it worth re-trying to enable the heal ?
Didn’t see any mention of that.
Yes, I made a change earlier today and reports are that it is working ok for others now.
