[SOLVED] How to get the state of an item whose name is stored in a String
  • Platform information:
    • Hardware: RPI 3B+
    • OS: Raspbian Stretch Lite
    • openHAB version: 2.5.M4
I am trying to use snips with openhab which has turned out pretty well. The following rule works for intents- Turn On and Turn Off but I am really confused over how to make it work for Toggle.
rule "Snips Voice Command"
    Item SnipsIntent received update
    var String entity = transform("JSONPATH", "$.slots..value.value", SnipsIntent.state.toString);
    var String onlyIntent = transform("JSONPATH", "$.intent.intentName", SnipsIntent.state.toString);
    if (onlyIntent == 'TurnOn') {
           sendCommand(entity,'ON')
    else if (onlyIntent == 'TurnOff') {
           sendCommand(entity,'OFF')
    else if (onlyIntent == 'Toggle') {
           if(entity.state == 'OFF')
           else
    var String sessionId = "{ \"sessionId\":\""+ transform("JSONPATH", "$.sessionId", SnipsIntent.state.toString) + "\" }"
    val actions = getActions("mqtt","mqtt:broker:snipsBrokerThingId")
    actions.publishMQTT("hermes/dialogueManager/endSession",sessionId)
I dont know how to implement this part.
           else
Here, if(entity.state == ‘OFF’) gives following error which is obvious.
'state' is not a member of 'java.lang.String'
How to find the state of the entity here??
I’m no familiar with Snips, but for the rules DSL, you can get an Item from a string using this…
Also, when comparing the states, you will want to use OnOffType.OFF rather than a string, and you were missing some curly braces…
if (item_derived_from_entity.state == OFF) {
    sendCommand(entity, 'ON')
} else {
    sendCommand(entity, 'OFF')
Hi !
Thanks a lot. It works.
:smile:
Great! Could you post your final rule in case it might be useful for others?
Sure. I am trying to add some more lines. I’ll post the final result in a while.
Here it is.
import org.eclipse.smarthome.model.script.ScriptServiceUtil
           val testItem = ScriptServiceUtil.getItemRegistry.getItem(entity)
           if(testItem.state == OnOffType.OFF)
                  sendCommand(testItem,'ON')
           else
                  sendCommand(testItem,'OFF')
