I recently installed OH2.1 Hasbian on RaspberryPi2. I would like to see my freshly created sitemap in my browser through BASIC_UI but it’s not there (I can see it in the android app). I read this may be caused by choosing ‘simple’ over ‘expert’ during installation, something I probably did ;-). I also read it should be installed through Paper_UI/config, but I do not see any reference to Basic_UI there. What can I do to install it?
Aha, you are right, but I only have the ‘tabs’: bindings, misc, and voice! So now the question is: why did I get less tabs?
@Guido_van_Haasteren
You could try editing your /services/addons.cfg
and choose another package, but I’m not sure if that will help.
package = expert
You may need to restart openHAB after the change.
Yes! That worked. It took a while to load, but then I had all the tabs and could install Basic UI.
Thanks!
