i have an mqtt topic that return
OFF 12315161
or
ON 15616814
and i want to separate the first word that is the command ( ON/OFF ) from the secondo word ( the timestamp )
i have tried to use
Type switch : state_arm_disarm “Alarm Arm State [%s]” [ stateTopic=“Paradox/Partition”, transformationPattern=“REGEX:^\S*” ]
but i get this error
Configuration model ‘mqtt.things’ has errors, therefore ignoring it: [5,114]: mismatched character ‘S’ expecting set null
[5,124]: no viable alternative at input ‘*’
[5,125]: mismatched character ‘<EOF>’ expecting ‘"’
i have tried also with
Type switch : state_arm_disarm “Alarm Arm State [%s]” [ stateTopic=“Paradox/Partition”, transformationPattern=“REGEX:(^\s*)” ]
If you have access to the source code of the MQTT sender then I would recommend that you change the way the data is sent.
This a bit of a misuse of MQTT, you should be sending two payloads in 2 topics if possible. Paradox/Partition/State : ON Paradox/Partition/Value : 12315161
This way you can link your channels directly, no transformation needed and easier to maintain with a MQTT tool
