[SOLVED] HSBType fails in Script
For the ambiguous function call, explicetly cast it to one or the other:
item.sendCommand(HSBType::fromRGB(125, 125, 125) as Command)
Similar problems occur when using DecimalType with sendCommand and postUpdate.
Sorry to inform that this does not work for HSBVAlue:
Group_DMX_LivingRoom.members.filter[l|l.state.toString != hsbOff.toString].forEach[l| sendCommand(l,hsbOff as Command) ]
or
Group_DMX_LivingRoom.members.filter[l|l.state.toString != hsbOff.toString].forEach[l| l.sendCommand(hsbOff as Command) ]
seems like hsbvalue can not be casted to command:(
Command should be State
Can still not figure out how to get rid off the ambigouse error:
Group_DMX_LivingRoom.members.filter[l|l.state.toString != hsbOff.toString].forEach[l| l.sendCommand(hsbOff as State) ]
or
Group_DMX_LivingRoom.members.filter[l|l.state.toString != hsbOff.toString].forEach[l| l.send(hsbOff as Command) ]
or
Group_DMX_LivingRoom.members.filter[l|l.state.toString != hsbOff.toString].forEach[l| l.postUpdate(hsbOff as HSBType) ]
does fix the problem
When all else fails, use .toString and move on to more interesting problems.
I would have expected pretty much all of those to work. I’m not sure what is going on but when you use toString it will force the code down a different path that should eliminate the error.
rule “SD_Rotgbfb”
Item SD_Red_Schalter received command
var DecimalType hue = new DecimalType(240) // 0-360; 0=red, 120=green, 240=blue, 360=red(again)
var PercentType sat = new PercentType(100) // 0-100
var PercentType bright = new PercentType(100) // 0-100
var light = new HSBType(hue,sat,bright)
SD_Red.sendCommand(light)
Ich habe das Problem, sendCommand ist Unterstrichen und der Compiler verweigert den Befehl
Item:
Color SD_Red “Rot” { channel=“hue:0210:1:bulb2:color” }
Switch SD_Red_Schalter
SSitemap: Switch item=SD_Red_Schalter mappings=[ON=“Click”]
Ich benutze Visual Studio Code mit Addon openhabian
ich bitte um Hilfe
danke
