Hi to all, i have a problem with a item.
I use HTTP Binding to read 2 seperate temperature from a webpage which are seperated with 2 comma like this 12.20,,20.20
The problem is that i tried many combinations of regex some of them loaded without errors and some of them didn’t work at all…i tried seperate with just the 1 temperature with the 2 comma to find where was the problem but still the value doesn’t load even when i don’t get any error in openhab log file.
I have installed Regex and the items load without error.
This is a try i made with just 1 temperature and the value which is trying to read was like this:
,,20.30
but it didn’t work either…
Number HTTPMesa "HTTPMesa [%.2f]" { http="<[http://192.168.1.12/index.html:5000:REGEX((?:(?!,,).)+(.*))]" }
The final result i try to be
2 Different Items
HTTP Temp1: 12.20
HTTP2 Temp: 20.20
