I am using the current stable release of Openhab (openHAB 2.3.0-1).
I always got my weather data from the http binding and the homepage http://wetterstation-pliening.info. The homepage has now been changed to https and since then I get the following error:
2018-10-20 18:22:23.193 [ERROR] [org.openhab.io.net.http.HttpUtil ] - Fatal transport error: javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
2018-10-20 18:22:23.198 [ERROR] [ab.binding.http.internal.HttpBinding] - No response received from 'weatherCache'
My items file looks like this:
Number Temperatur "Temperatur [%.1f °C]" <temperature> (Wetter) { http="<[weatherCache:1000:REGEX(.*?Temperatur.*?<th class="col1 leftalign">(.*?) °C.*)]" }
And my http.cfg looks like this:
weatherCache.url=https://wetterstation-pliening.info
weatherCache.updateInterval=60000
Before I switched to https everything worked fine? Is this a Java bug? Or does the certificate from https://wetterstation-pliening.info have an error? Chorme does not display a certificate error.
