Dear all
due to network upgrade I had to do a factory reset on my Hue Bridge (square).
According to the hints in the log I tried to replace the previous user:
20-Mai-2018 18:04:24.929 [WARN ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - User KdUL58anz8KrK184IdcXWz5U9RLUpf4fQOB8jvOQ is not authenticated on Hue bridge 192.168.1.44
20-Mai-2018 18:04:24.929 [WARN ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - Please configure a valid user or remove user from configuration to generate a new one.
20-Mai-2018 18:04:25.180 [INFO ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - Creating new user on Hue bridge 192.168.1.44 - please press the pairing button on the bridge.
20-Mai-2018 18:04:34.989 [WARN ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - User KdUL58anz8KrK184IdcXWz5U9RLUpf4fQOB8jvOQ is not authenticated on Hue bridge 192.168.1.44
20-Mai-2018 18:04:34.989 [WARN ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - Please configure a valid user or remove user from configuration to generate a new one.
20-Mai-2018 18:04:35.213 [INFO ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - Creating new user on Hue bridge 192.168.1.44 - please press the pairing button on the bridge.
20-Mai-2018 18:04:35.230 [INFO ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - User '8Ohtm159URbKLFP5L645mLEv7ydicCBqZdhA5Z1U' has been successfully added to Hue bridge.
20-Mai-2018 18:04:45.037 [WARN ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - User KdUL58anz8KrK184IdcXWz5U9RLUpf4fQOB8jvOQ is not authenticated on Hue bridge 192.168.1.44
20-Mai-2018 18:04:45.037 [WARN ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - Please configure a valid user or remove user from configuration to generate a new one.
20-Mai-2018 18:04:55.089 [WARN ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - User KdUL58anz8KrK184IdcXWz5U9RLUpf4fQOB8jvOQ is not authenticated on Hue bridge 192.168.1.44
20-Mai-2018 18:04:55.090 [WARN ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - Please configure a valid user or remove user from configuration to generate a new one.
20-Mai-2018 18:05:05.148 [WARN ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - User KdUL58anz8KrK184IdcXWz5U9RLUpf4fQOB8jvOQ is not authenticated on Hue bridge 192.168.1.44
20-Mai-2018 18:05:05.149 [WARN ] [pse.smarthome.binding.hue.handler.HueBridgeHandler] - Please configure a valid user or remove user from configuration to generate a new one.
Means:
- deleted the existing user from the thing file --> saved without user
- log file hinted my to push the pairing buttong --> done
- new user appeared in log file --> copied to thing filed --> saved
But still this WARN appears that I have to remove the old user.
What can I do?
Thanks & regards
John
