Hi All,
I have an issue with a Hue LED bulb group where I define the group item as below and the sitemap as indicated. I understand that the same item can be used for ON/OFF as well as percent.
I am sure this was working but perhaps one of my little ‘tweaks’ broke something.
I should point out the lights all work well and set to the correct level and state as directed using Alexa. just the web UI is not functioning well.
Help appreciated.
**.items
Each LED is configured through PaperUI not a text file.
There are four HUE LEDs all in a group and I use the group to set them on/off or the brightness level.
Group gKitchen_Light_Dimmer
,sitemap
Slider item=gKitchen_Light_Dimmer label="Ceiling [%.0f]" icon="light"
Switch item=gKitchen_Light_Dimmer label="Ceiling"
Issue Description
The BasicUI displays Err label next to a slider.
LOG:
2018-03-20 17:45:53.081 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Exception while formatting value 'OFF' of item gLiving_Light_Dimmer with format '%.0f': {}
java.util.IllegalFormatConversionException: f != java.lang.String
at java.util.Formatter$FormatSpecifier.failConversion(Formatter.java:4302) [?:?]
at java.util.Formatter$FormatSpecifier.printFloat(Formatter.java:2806) [?:?]
at java.util.Formatter$FormatSpecifier.print(Formatter.java:2753) [?:?]
at java.util.Formatter.format(Formatter.java:2520) [?:?]
at java.util.Formatter.format(Formatter.java:2455) [?:?]
at java.lang.String.format(String.java:2940) [?:?]
at org.eclipse.smarthome.core.library.types.OnOffType.format(OnOffType.java:29) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getLabel(ItemUIRegistryImpl.java:372) [155:org.eclipse.smarthome.ui:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.AbstractWidgetRenderer.preprocessSnippet(AbstractWidgetRenderer.java:118) [224:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.SliderRenderer.renderWidget(SliderRenderer.java:51) [224:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:172) [224:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:137) [224:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:100) [224:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.smarthome.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:179) [224:org.eclipse.smarthome.ui.basic:0.10.0.b1]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
2018-03-20 17:46:00.340 [vent.ItemStateChangedEvent] - AstroSunData_Position_Azimuth changed from 287.59 to 287.40
2018-03-20 17:46:00.355 [vent.ItemStateChangedEvent] - SunElevation changed from 19.47 to 19.29
2018-03-20 17:46:00.362 [vent.ItemStateChangedEvent] - AstroSunData_Position_Elevation changed from 19.47 to 19.29
2018-03-20 17:46:02.245 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Exception while formatting value 'OFF' of item gKitchen_Light_Dimmer with format '%.0f': {}
2018-03-20 17:46:02.278 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-03-20 17:46:02.286 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'KTSO2' for widget org.eclipse.smarthome.model.sitemap.Text
2018-03-20 17:46:02.293 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'KTSO2' for widget org.eclipse.smarthome.model.sitemap.Text
2018-03-20 17:46:02.299 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'KTSO2' for widget org.eclipse.smarthome.model.sitemap.Text
