- OS: Debian 10.0 with java 11.0
- openHAB version:Last, downloaded Satarday.
Hello all, I’ve worked with Openhab 1 then migrated to 2 and now Im in the process to upgrade to 3 and there the problems start. My plan is to develop the Openhab enviroments in a file-based basis (like as I used in 1 and 2)but Im having This stupid error when setting MQTT. (I always used MQTT 1.0 in all my projects until now… not a bug fan of Things .
Below My example:
addons.cfg
package = standard
remote = true
binding =astro,mqtt,exec,telegram
#persistence=jdbc-mysql
transformation =xslt,map,regex,javascript,jsonpath,exec
ui =basic
Things:
"Bridge mqtt:broker:MyMQTTBroker “Mosquitto” @ “System” [ host=“192.168.1.51”, secure=false, username=“myuser”, password=“mypass”] {
Thing topic CPE_Pe “test lamp” [ availabilityTopic=“testopic/LWT”, payloadAvailable=“Online”, payloadNotAvailable=“Offline”] {
Channels:
Type switch : CPE_Pe_SW “test lamp” [ commandTopic=“testopic” , on=“ON”, off=“OFF”]
Items:
“Switch Sala_CPE “Test Light” { ga=“Light”, channel=“mqtt:topic:myMQTTBroker:CPE_Pe:CPE_Pe_SW” }”
sitemap:
"sitemap test {
Frame {
Switch item=Sala_CPE label=“Test Switch”
What in the hell am I doing wrong? the Broker connects fine, I have no errors but no messages are published to mqtt, also when I press the switch to ON it returns to the OFF imediatly and in the events.log I have the warning:
2021-05-31 15:36:09.423 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘Sala_CPE’ received command ON
2021-05-31 15:36:09.429 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘Sala_CPE’ predicted to become NULL
Some help please
