i need help to get things status so when the things go to OFFLINE / ONLINE then the lebel of the item in Basic UI (sitemap) will change the color (not the valuecolor that is set in my sitemap and working)
how do i do that?
thanks.
You can’t. sitemap only takes notice of Items.
So you’d need a rule that watches for Thing status changes
and updates some Item that you can then use to control labelcolor=
of your sitemap widgets.
thanks this is my rule that help me after i change it to my thing
rule "shelly:shelly1:f4cfa2749b0e"
Thing "shelly:shelly1:f4cfa2749b0e" changed
var thingStatusInfo = getThingStatusInfo("shelly:shelly1:f4cfa2749b0e")
if ((thingStatusInfo !== null) && (thingStatusInfo.getStatus().toString() == "ONLINE")) {
logInfo("ThingStatus", "shelly_shelly1_f4cfa2749b0e_relay_output is online.")
shelly_shelly1_f4cfa2749b0e_relay_output.postUpdate(ON)
} else {
logError("ThingStatus", "shelly_shelly1_f4cfa2749b0e_relay_output is offline or doesn't exist.")
shelly_shelly1_f4cfa2749b0e_relay_output.postUpdate(NULL)
