[SOLVED] iCloud Unable to refresh device data
I have started to see the error below very regularly filling up my logs.
Doe any one have this and any ideas for a solution. seems similar to one we had not so long ago.
2018-10-26 08:56:13.463 [WARN ] [d.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
	at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946) ~[?:?]
	at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316) ~[?:?]
	at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310) ~[?:?]
	at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639) ~[?:?]
	at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223) ~[?:?]
	at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037) ~[?:?]
	at sun.security.ssl.Handshaker.process_record(Handshaker.java:965) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379) ~[?:?]
	at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559) ~[?:?]
	at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1334) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1309) ~[?:?]
	at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:259) ~[?:?]
	at org.openhab.binding.icloud.internal.Connection.postRequest(Connection.java:95) ~[?:?]
	at org.openhab.binding.icloud.internal.Connection.requestDeviceStatusJSON(Connection.java:55) ~[?:?]
	at org.openhab.binding.icloud.handler.ICloudAccountBridgeHandler.lambda$0(ICloudAccountBridgeHandler.java:81) ~[?:?]
	at org.eclipse.smarthome.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:81) ~[?:?]
	at org.eclipse.smarthome.core.cache.ExpiringCache.getValue(ExpiringCache.java:61) ~[?:?]
	at org.openhab.binding.icloud.handler.ICloudAccountBridgeHandler.refreshData(ICloudAccountBridgeHandler.java:132) ~[?:?]
	at org.openhab.binding.icloud.handler.ICloudAccountBridgeHandler.lambda$1(ICloudAccountBridgeHandler.java:123) ~[?:?]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
	at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:397) ~[?:?]
	at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:302) ~[?:?]
	at sun.security.validator.Validator.validate(Validator.java:262) ~[?:?]
	at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) ~[?:?]
	at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229) ~[?:?]
	at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124) ~[?:?]
	at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1621) ~[?:?]
	... 26 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
	at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141) ~[?:?]
	at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126) ~[?:?]
	at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) ~[?:?]
	at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:392) ~[?:?]
	... 26 more
The error looks like Apple changed their SSL certificate.
What version of Java are you running? Perhaps an upgrade will resolve it. An upgrade of Java should include updated trusted CAs.
I’m just guessing though.
See: Icloud binding - General SSLEngine problem
no updates pending I am on the latest for my distro
Java™ SE Runtime Environment (build 1.8.0_191-b12)
Java HotSpot™ 64-Bit Server VM (build 25.191-b12, mixed mode)
I fixed this back in July/August when the commands to download the new certificates were provided in the thread you posted.
I have tried again this time and see no improvement this time.
I will read once more through that thread in case I missed something
Went back through the old thread which I had corrected a few months ago and did the same thing again. It is now working correctly after restarting Openhab.
I have no idea why it suddenly dropped back to not knowing the cert.
Thanks for your responses
Paul
Can you post a link to the old thread that fixed the problem? That will help future users find the solution when they have this same problem.
It is already there, the link is in the post #3 and in the solved by segment.
