I connected my first IKEA Trådfri bulb just now: Number GF_Stairway_Light_Dimmer "Stairway Light Brightness " {channel="tradfri:0100:blablabla:65538:brightness"}
And I put a rule in to adjust the brightness when it is turned on.
But it seems the brightness the bulb is reporting is a decimal type (0.8, 0.5 et cetera) and not what all my other lights are using (80, 50 int type, percentage).
I don’t see other cases of this in the forums, is there something in my setup or something I have misunderstood?
I can adjust my values to something IKEA would like better, but if I can get the IKEA Bulb to behave like the rest of my lights that’s better of course.
What type of Item is linked to the Brightness/Dimmer channel of the bulb? Usually the entry for the Channel in PaperUI will tell you what you must use.
Thanks! In other words the error was in the definition of the Item where I had put in Number instead of Dimmer (which all my other dimmers are defined as as well).
