I have some temperatures going into influxdb from openhab. Working fine.
But for each item they get a table each. Under influx, these temperatures would most likely make sense into one table (temperatures) with tags for the room/sensor being used.
This would allow for better math across an entire household.
If this possible in openhab, or do I need to do something externally to roll up all the distinct tables into one.
Not possible. I’m no InfluxDB expert but what math would putting them in the same table allow that querying across the multiple tables doesn’t allow?
You could always keep the separate ones separate and add a new single item that gets updated and persisted with the value for any of the sensors. That will put all your measurements in the same table.
But Persistence is designed to work with any database, as diverse as SQL types like MySQL, NoSQL types like Mongo, time series types like InfkuxDB, and more. It necessarily results in the lowest common denominator in terms of functionality.
Another option for that is too put them into a Group:Number:AVG and persist the group without the *. I do this for my indoor temp and humidity sensors.
