I have installed openHab on a Intel® Compute Stick STK1AW32SC.
Installation works great.
Except starting the service gives me the following error–>
STATUS | wrapper | 2019/01/12 19:15:56 | --> Wrapper Started as Service
STATUS | wrapper | 2019/01/12 19:15:57 | Launching a JVM…
FATAL | wrapper | 2019/01/12 19:15:57 | Unable to execute Java command. Het systeem kan het opgegeven bestand niet vinden. (0x2)
FATAL | wrapper | 2019/01/12 19:15:57 | “%JAVA_HOME%\bin\java” -Dkaraf.home=“C:\openhab-2.4.0\runtime” -Dkaraf.base=“C:\openhab-2.4.0\userdata” -Dkaraf.data=“C:\openhab-2.4.0\userdata” -Dkaraf.etc=“C:\openhab-2.4.0\userdata\etc” -Dcom.sun.management.jmxremote -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -Djava.endorsed.dirs="%JAVA_HOME%\jre\lib\endorsed;%JAVA_HOME%\lib\endorsed;C:\openhab-2.4.0\runtime\lib\endorsed" -Djava.ext.dirs="%JAVA_HOME%\jre\lib\ext;%JAVA_HOME%\lib\ext;C:\openhab-2.4.0\runtime\lib\ext" -Dopenhab.home=“C:\openhab-2.4.0” -Dopenhab.conf=“C:\openhab-2.4.0\conf” -Dopenhab.runtime=“C:\openhab-2.4.0\runtime” -Dopenhab.userdata=“C:\openhab-2.4.0\userdata” -Dopenhab.logdir=“C:\openhab-2.4.0\userdata\logs” -Dfelix.cm.dir=“C:\openhab-2.4.0\userdata\config” -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Xmx512m -Djava.library.path=“C:\openhab-2.4.0\userdata\lib\wrapper\” -classpath “C:\openhab-2.4.0\runtime\lib\boot\activation-1.1.1.jar;C:\openhab-2.4.0\runtime\lib\boot\jaxb-api-2.3.0.jar;C:\openhab-2.4.0\runtime\lib\boot\jaxb-core-2.2.11.jar;C:\openhab-2.4.0\runtime\lib\boot\jaxb-impl-2.2.11.jar;C:\openhab-2.4.0\runtime\lib\boot\org.apache.karaf.diagnostic.boot-4.2.1.jar;C:\openhab-2.4.0\runtime\lib\boot\org.apache.karaf.jaas.boot-4.2.1.jar;C:\openhab-2.4.0\runtime\lib\boot\org.apache.karaf.main-4.2.1.jar;C:\openhab-2.4.0\runtime\lib\boot\org.osgi.core-6.0.0.jar;C:\openhab-2.4.0\userdata\lib\wrapper\karaf-wrapper-main.jar;C:\openhab-2.4.0\userdata\lib\wrapper\karaf-wrapper.jar” -Dwrapper.key=“V3of0CUYQWvKVUsD” -Dwrapper.port=32000 -Dwrapper.jvm.port.min=31000 -Dwrapper.jvm.port.max=31999 -Dwrapper.pid=6408 -Dwrapper.version=“3.2.3” -Dwrapper.native_library=“wrapper” -Dwrapper.service=“TRUE” -Dwrapper.cpu.timeout=“10” -Dwrapper.jvmid=1 org.apache.karaf.wrapper.internal.service.Main
FATAL | wrapper | 2019/01/12 19:15:57 | Critical error: wait for JVM process failed
never mind. FOund it.
I forgot the JAVA_HOME variable
Add the JAVA_HOME
System Environment Variable in Windows. Navigate to:
- Control Panel
System and Security
System
Advanced System Settings
Environment Variables
System Variables
