This is good advise me thinks
Alex @Celaeno1 check out this post in another thread Rob explains about how to use this tool
this also seems like some sound thinking to me
My understanding is silicon are handing it all over to the zwave association this year and the code for all the bits that is currently closed will be available to some developers. I believe they may be treating openzwave as a special case so why not your work which is equally a special case?
Well, I donāt think thatās quite right. The focus of the ZWA will change, and Silabs will open source the protocols so that other manufacturers can get into the market. ZWA will sort out the certification/standards side of things.
I have been working with Silabs for a few years - Iāve no idea what OZW are doing, and its not really of interest as itās not linked.
I am under an NDA with Silabs, so canāt really comment too much on whatās happening, and I doubt they will be releasing a lot of information until probably at least the middle of the year.
Thanks Chris,
While I donāt dislike Z/IP I donāt really need it so I can stop working on it and see what happens.
Bravo Stephen
your work has helped fix a problem which so many users have suffered from
thanks Chris and Stephen, great work fellas!
Can you please post the link to this JAR?
Best, Jay
First, it is not designed for OH 2.4. I know GH was updated 7 hours ago, before the latest binding build. I am not sure whether it was fixed before the last export. The jar is here.
https://ci.openhab.org/view/Integration%20Builds%20(2.5.x)/job/openHAB2.5.x-ZWave/
EDIT: The binding was updates 5 hours ago so you will need to wait for another binding export and snapshot buildā¦
Note that this is just the standard 2.5.x SNAPSHOT.
The snapshot build was done when I did the update.
Iāve been running Chrisās zWave 2.5 bindings on 2.4 OH for quite some time now. Hereās the one Iāve been running since Oct 2019 w/o any major issues. Iāll let folks know if this new one above works on 2.4 when I get a chance to try it.
287 ā Active ā 80 ā 2.5.0.201910162319 ā org.openhab.binding.zwave
Best. Jay
It works! I have 20 zWave devices which are all online and reporting after the upgrade.
With OH 2.4 running the latest zWave binding, you have to install the Zigbee binding tied to zWave binding in order to get zWave to work on OH 2.4. The Zigbee binding will throw a bunch of errors on a clean startup of OH 2.4 which you can ignore.
290 ā Active ā 80 ā 2.5.2.202002091130 ā org.openhab.binding.zwave
200 ā Active ā 80 ā 2.5.0.201910162318 ā org.openhab.binding.zigbee
Best, Jay
