Folks,
I’ve a solution that works for me when you see in your logs something like:
2019-02-09 15:04:53.137 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 6024300 failed: null
2019-02-09 15:04:53.139 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
I think this is related to your app on your iPhone or Android.
Please check your App configuration, in my case changing the remote URL configuration from
https://myopenhab.org:443
to
solved the issue. Now I don’t see any other similar log.
Check also the Local URL,
http://192.168.x.x:8080
worked for me.
Hope this helps
Andrea
