I have two ZWave water sensors installed in my home and have created the rule below, although the code works fine I don’t believe I’m being very efficient. So I’m looking for any advice on how I achieve the same but maybe with less code? If that’s possible or have do I just stick with this code?
rule "Water Alarms"
Item Kitchen_ST812_Flood_Alarm changed or
Item Study_ST812_Flood_Alarm changed
var String Water_Alarm = null
if(Kitchen_ST812_Flood_Alarm.state == ON) {
Water_Alarm = "Your attention please! Water has been detected in the Kitchen."
notifyMyAndroid("Water Alarm", "Water has been detected in the Kitchen")
} else if(Kitchen_ST812_Flood_Alarm.state == OFF) {
Water_Alarm = "Kitchen water alarm! has now cleared."
} else if(Study_ST812_Flood_Alarm.state == ON) {
Water_Alarm = "Attention please! Water has been detected in the Study."
notifyMyAndroid("Water Alarm", "Water has been detected in the Study")
} else if(Study_ST812_Flood_Alarm.state == OFF) {
Water_Alarm = "Study water alarm! has now cleared."
setMasterVolume(new PercentType(50))
say(Water_Alarm)
There are many different ways to do that. One solution
rule "Kitchen_ST812_Flood_Alarm ON"
Item Kitchen_ST812_Flood_Alarm changed to ON
say("Your attention please! Water has been detected in the Kitchen.")
rule "Kitchen_ST812_Flood_Alarm OFF"
Item Kitchen_ST812_Flood_Alarm changed to OFF
say("Kitchen water alarm! has now cleared.")
rule "Study_ST812_Flood_Alarm ON"
Item Study_ST812_Flood_Alarm changed to ON
say("Attention please! Water has been detected in the Study.")
rule "Study_ST812_Flood_Alarm OFF"
Item Study_ST812_Flood_Alarm changed to OFF
say("Study water alarm! has now cleared.")
If you implement your code as you have it there you will never have a situation where you see the alarm for the study. Since the Kitchen alarm will always either be ON or OFF your if statement will never get to the bottom two cases. Unless the kitchen alarm state is NULL.
I would recommend structuring your Rule according to Design Pattern: How to Structure a Rule and some String manipulation which will result in something like:
rule "Water Alarms"
// 1. Decide if the Rule needs to run
if(previousState == NULL) return; // we don't run on changes from the NULL state
// 2. Calculate what needs to be done
val room = triggeringItem.name.split("_").get(0)
val sayMsg = if(triggeringItem.state == ON) "Water has been detected in the " + room else room + " water alarm! has now cleared."
val nma = if(triggeringItem.state == ON) "Attention please! Water has been detected in the " + room else ""
// 3. Do it
if(nma != "") notifyMyAndroid("Water Alarm", nma)
say(sayMsg)
It isn’t really fewer lines of code, but the code is more generic so if you needed to add more alarms later all you have to do is add them as triggers to the Rule. Or even better, create a Group and change the Rule trigger to Member of WaterAlarms changed (assuming you name the Group “WaterAlarms”).
It is also more maintainable in the future because if you ever want to change from using NMA to something else, or you have other things you want to do when the alarm is on, you only have to do it on ine place rather than the 2-4 places you would have to make changes in the current Rule.
I’ll also point you to Design Pattern: Separation of Behaviors which you can use to centralize your NMA and alerting because I’m going to guess this isn’t the only Rule you have where you want say and NMA alerts.
Then your Rules become something like the following:
rule "Alert!"
Item InfoAlert received command or
Item AlarmAlert received command
say("Attention please! " + receivedCommand)
if(triggeringItem.name == "AlarmAlert") notifyMyAndroid(receivedCommand)
rule "Water Alarms"
val alertMsg = if(triggeringItem.state == ON) "Water has been detected in the " + room else room + " water alarm! has now cleared."
// 3. Do it
if(triggeringItem.state == ON) aAlert.sendCommand(alertMsg)
else aInfo.sendCommand(alertMsg)
Not a significant savings in code if you are only alerting in this one Rule. But if more Rules you have that alert the more savings you get. Also, if you decide to use some other service instead of NMA or want to have more complex rules (e.g. I use a one alerting service during the day and differnt one at night) you only have to code that in one place.
