i have a problem with the ISM8 binding since upgrading Openhab to version 4.2.2.
I see the following warnings at the log and the things don’t update anymore:
2024-11-13 18:31:20.679 [WARN ] [ab.binding.ism8.internal.Ism8Handler] - Ism8: ID couldn't be converted correctly. Check the configuration of channel Kesseltemperatur. Cfg=Configuration[{key=type; type=String; value=9.001}, {key=id; type=BigDecimal; value=4.0}] 2024-11-13 18:31:20.680 [WARN ] [ab.binding.ism8.internal.Ism8Handler] - Ism8: Channel=Configuration[{key=type; type=String; value=9.001}, {key=id; type=BigDecimal; value=4.0}] failed to register datapoint 2024-11-13 18:31:20.680 [WARN ] [ab.binding.ism8.internal.Ism8Handler] - Ism8: ID couldn't be converted correctly. Check the configuration of channel Anlagendruck. Cfg=Configuration[{key=type; type=String; value=9.006}, {key=id; type=BigDecimal; value=13.0}] 2024-11-13 18:31:20.680 [WARN ] [ab.binding.ism8.internal.Ism8Handler] - Ism8: Channel=Configuration[{key=type; type=String; value=9.006}, {key=id; type=BigDecimal; value=13.0}] failed to register datapoint 2024-11-13 18:31:20.680 [WARN ] [ab.binding.ism8.internal.Ism8Handler] - Ism8: ID couldn't be converted correctly. Check the configuration of channel Temperatur Solarthermiekollektor. Cfg=Configuration[{key=type; type=String; value=9.001}, {key=id; type=BigDecimal; value=137.0}] 2024-11-13 18:31:20.680 [WARN ] [ab.binding.ism8.internal.Ism8Handler] - Ism8: Channel=Configuration[{key=type; type=String; value=9.001}, {key=id; type=BigDecimal; value=137.0}] failed to register datapoint 2024-11-13 18:31:20.680 [WARN ] [ab.binding.ism8.internal.Ism8Handler] - Ism8: ID couldn't be converted correctly. Check the configuration of channel Ausentemperatur. Cfg=Configuration[{key=type; type=String; value=9.001}, {key=id; type=BigDecimal; value=8.0}] 2024-11-13 18:31:20.680 [WARN ] [ab.binding.ism8.internal.Ism8Handler] - Ism8: Channel=Configuration[{key=type; type=String; value=9.001}, {key=id; type=BigDecimal; value=8.0}] failed to register datapoint 2024-11-13 18:31:20.680 [WARN ] [ab.binding.ism8.internal.Ism8Handler] - Ism8: ID couldn't be converted correctly. Check the configuration of channel Störung. Cfg=Configuration[{key=type; type=String; value=20.105}, {key=id; type=BigDecimal; value=1.0}]
Within ISM8 Thing the configuration is displayed only within the code Tab:
UID: ism8:device:3920d871fe
label: Heizung ISM8i
thingTypeUID: ism8:device
configuration:
portNumber: 12004
channels:
- id: ism8_kesseltemperatur
channelTypeUID: ism8:number-readonly
label: Kesseltemperatur
description: ""
configuration:
type: "9.001"
- id: ism8_anlagendruck
label: Anlagendruck
description: ""
configuration:
type: "9.006"
- id: ism8_temperatur_solarkollektor
label: Temperatur Solarthermiekollektor
description: ""
configuration:
type: "9.001"
- id: ism8_aussentemperatur
label: Ausentemperatur
description: ""
configuration:
type: "9.001"
- id: ism8_stoerung
label: Störung
description: ""
configuration:
type: "20.105"
- id: ism8_brennerleistung
label: Brennerleistung
description: ""
configuration:
type: "5.001"
- id: ism8_warmwassertemperatur
label: Warmwassertemperatur
description: ""
configuration:
type: "9.001"
- id: ism8_heizkreispumpe
channelTypeUID: ism8:switch-readonly
label: Heizkreispumpe
description: ""
configuration:
type: "1.001"
- id: ism8_speicherladepumpe
label: Speicherladepumpe
description: ""
configuration:
type: "1.001"
- id: ism8_ruecklauftemperatur
label: Rüclauftemperatur
description: ""
configuration:
type: "9.001"
- id: ism8_betriebsart
label: Betriebsart
description: ""
configuration:
type: "20.105"
- id: ism8_solar_durchfluss
label: Solar Durchfluss
description: ""
configuration:
type: "13.002"
- id: ism8_programm_heizkreis
label: Programm Heizkreis
description: ""
configuration:
type: "20.102"
- id: ism8_solar_Eingang_temperatur
label: Solar Temperatur Eingang
description: ""
configuration:
type: "9.001"
- id: ism8_warmwasserladung
label: 1x Warmwasser
description: ""
configuration:
type: "1.001"
- id: ism8_Warmwassertemperatur_Solar_1
label: Warmwassertemperatur Solar 1
description: ""
configuration:
type: "9.001"
- id: ism8_solar_e1_durchfluss
label: Solar Durchfluss (E1)
description: ""
configuration:
type: "13.002"
- id: ism8_Status_Solarkreispumpe
label: Status Solarkreispumpe SKP1
description: ""
configuration:
type: "1.001"
- id: ism8i_Sammlertemperatur
label: Sammlertemperatur
description: ""
configuration:
type: "9.001"
- id: ismi8_status_dreiwegeventil
label: Status 3-Wege-Umschaltventil
description: ""
configuration:
type: "1.009"
- id: ism8i_stoerung_systembedienmodul
label: Störung BM-2
description: ""
configuration:
type: "1.001"
- id: ism8i_Warmwassersolltemperatur
label: Warmwassersolltemperartur
description: ""
configuration:
type: "9.001"
- id: ism8i_programm_warmwasser
label: Programmwahl Warmwasser
description: ""
configuration:
type: "20.103"
- id: ism8i_Sollwertkorrektur
label: Sollwertkorrektur
description: ""
configuration:
type: "9.002"
- id: ism8i_stoerung_solarmodul
label: Status Solarmodul
description: ""
configuration:
type: "1.001"
I tried till now:
- restarted OpenHab
- cleared OH cache and restarted OpenHab
- stopped ISM8-Item, waited some seconds and started Item again
The mentioned warnings show up after restarting the Item.
There was no change in configuration around OH (ISM8, Network, etc.).
Anyone an idea where to start analyzing / debugging ?
Regards
BoxSon
