I have a setup setup for several items now and they all work great. They all work with mqtt so not sure if this makes a difference or not. But now I am trying to do a setpoint with a wemo item and I am getting an error when I load the item file.
here is what i have. this is the wemo switch and then the number item i added.
Switch Table_Heater "Table Heater" <heating> { channel="wemo:socket:Socket-1_0-221806K01011EF:state" }
Number Table_Heater_Thermostat_SP_F "Set Point [%.1f]" { channel="wemo:socket:Socket-1_0-221806K01011EF/set_point:command:*:default]" }
I get this error:
[ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'channel' of item 'Table_Heater_Thermostat_SP_F' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: ID segment 'Socket-1_0-221806K01011EF/set_point' contains invalid characters. Each segment of the ID must match the pattern [A-Za-z0-9_-]*.
I tried changing it to several things. I found other channel examples. but none of them seem to work:
item:
Number Table_Heater_Thermostat_SP_F "Set Point [%.1f]" { channel="wemo:socket:Socket-1_0-221806K01011EF:state#SETPOINT]" }
error:
org.eclipse.smarthome.model.item.BindingConfigParseException: UID segment 'state#SETPOINT]' contains invalid characters. The last segment of the channel UID must match the pattern [A-Za-z0-9_-#]*
i googled this [A-Za-z0-9_-#]* and just really can’t figure out what that means… sorry!
