Hello all,
I am having an issue with valuecolor when assigning to derived item - it does not work as described in the documentation and i wonder what i did wrong…
I have a NetAtmo unit that can measure both actual temperature (as a number) and also reports trend as a string. I also use a string item to combine those.
Number Apt_LR_Temperature "Temperature [%.1f °C]" <temperature> (Apt_Temperature,Apt_LivingRoom) [""] {channel="netatmo:NAMain:fe908471:70ee50369ad0:Temperature"}
String Apt_LR_Temp_Trend " [%s]" <temperature> (Apt_LivingRoom) [""] {channel="netatmo:NAMain:fe908471:70ee50369ad0:TempTrend"}
String Apt_LR_Temp_with_Trend "Temperature [%s]" <temperature> (Apt_LivingRoom)
In the rules I have the following code to update the combined string item whenever there is an update like this:
rule "update Apt_LR_Temp_with_Trend"
Item Apt_LR_Temperature received update
Apt_LR_Temp_with_Trend.postUpdate(Apt_LR_Temperature.getState().format("%.1f °C") + " (" + Apt_LR_Temp_Trend.state + ")")
Overall this works fine except that I cannot format the color of the combined string item based on the original temperature item.
The basic temperature item coloring in the sitemap works fine like this:
Text item=Apt_LR_Temperature valuecolor=[Apt_LR_Temperature=="NULL"="lightgray",Apt_LR_Temperature>=30="red",>25="orange",>=20="green",>=15="orange",<15="blue"]
The same formatting for the combined string item does not - always uses default color…:
Text item=Apt_LR_Temp_with_Trend valuecolor=[Apt_LR_Temperature=="NULL"="lightgray",Apt_LR_Temperature>=30="red",>25="orange",>=20="green",>=15="orange",<15="blue"]
The way i read the documentation the item_name
in valuecolor does not need to be the item actually being displayed right?
I see no errors or warnings in the logs…
Can you please point me to my mistake
Thanks in advance!
- Platform information:
- Hardware: synology NAS
- OS: synology DSM
- Java Runtime Environment: not sure… whatever the docker has
- openHAB version: openhab 2.4.0 running in a docker container
