Have upgraded to 3 and getting the hang of it.
Having an issue with the MiFlora setup.
I have the daemon from thomas setup and running. Logging the data coming in from the miflora is running great.
[2021-10-12 03:05:43] Retrieving data from sensor "Sensor4" ...
[2021-10-12 03:05:43] Result: {"light": 14, "temperature": 22.7, "moisture": 0, "conductivity": 0, "battery": 100}
[2021-10-12 03:05:43] Publishing to MQTT topic "miflora/Sensor4"
I added a thing and it shows online.
I setup a channel…
UID: mqtt:topic:mqttbroker:sensor_4
label: Sensor 4
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:mqttbroker
channels:
- id: sensor4_light
channelTypeUID: mqtt:number
label: Sensor 4 Light
description: ""
configuration:
stateTopic: miflora/Sensor4/light
and added an item.
I get nothing coming back. Just null. Nothing occurs in the log when the sensor updates.
I am not sure how to configure the JSON. I tried a couple of options…
JSONPATH:$.light
JSONPATH:$.sensor_4.light
Neither seem to change anything.
Yes, I have the transform installed. I use for a sonoff POW to read the power data. No issue there.
Can’t figure out why my item wont update…
Thanks!
