I have a file (let’s say ‘powerstatus’) that has only 2 values 0 or 1.
(This is just a script on another server that echo 0 or 1 into that file.)
Is there a way that I create an item ‘from’ this file?
Or what’s a good way?
The end goal is to update an item with the power status of servers. That I can use in rules, sitemaps…
And linked with this, send out messages, reboot/shutdown machines…
Hereby the convert rule, and the rule that’s been triggered by it:
rule "check powerstatus of Hypervisor"
//Convert textvalue 0 or 1 towards OH item ON or OFF.
Time cron "0 0/1 * * * ?"
Thread::sleep(10000) // Give other server some time
var String result = executeCommandLine("cat /diy/power_status",2000)
if (result == "0") {
HypervisorPower.postUpdate(OFF)
else if (result == "1") {
HypervisorPower.postUpdate(ON)
rule "Action for Hypervisor on power failure"
//Trigger action if power is lost
Item HypervisorPower changed from ON to OFF
<knip>
ps The thread of 10 sec is because the other server is also trigger every minute. This way, I’m sure that the other server is finished with his check. Else I would lose a whole minute, and with my small UPS…
So why not trigger the rule using `10 0/1 * * * ?" ? This is functionally equivalent to what you are doing only you won’t be tying up a runtime thread waiting for those ten seconds.
