Hello folks,
my logfiles have many entries like: “item xy predicted to become…”, this is a litte annoying (to me, maybe to others, too?).
To get rid of these entries, see solution!
Hello folks,
SOLUTION:
in karaf console:
log:set ERROR smarthome.event.ItemStatePredictedEvent
turning back:
log:set DEFAULT smarthome.event.ItemStatePredictedEvent
Additional comment : Sometimes it will be worth considering the underlying cause, rather than just suppressing the message.
The "predicted..."
message comes from the autoupdate feature, guessing the effect of a command on the Item’s state.
Sometimes you want that, sometimes it is unnecessary - because you get a prompt status update back from a real device, say.
Autoupdate is enabled by default, but can be disabled for individual Items.
Additional information:
autoupdate
autoupdate="false"
is a special instruction which keeps the current state of the item, even if a command has been received. This way, the Item is unchanged unless you explicitly post an update to the item.
Example:
Switch Garage_Gate {binding="xxx", autoupdate="false"}
see also here:
