[SOLVED] Items receive commands but stopped to update their states
Can you tell me the addresses of the devices that aren’t working? You blanked them out above so it’s not really easy for me to tell what they are :wink:
Thanks @rossko57, you’re right :smiley:
@chris, here we go:
Dimmer TestItem_Working {channel="zigbee:device:0137F59F:00124b00157d8e53:00124B00157D8E53_1_dimmer"}
Dimmer TestItem_NotWorking {channel="zigbee:device:0137F59F:0017880103d08243:0017880103D08243_11_dimmer"}
Just as background to illuminate your results - for @chris too
I did some experiments with autoupdate …
Yes, the behaviour is different with allowing it to default per Item, and deliberately setting autoupdate="true". True forces autoupdate action, overriding any veto from the channel.
This is a revelation to me - an Item can effectively have one of three autoupdate policies - disabled (false), enabled (default), forced (true).
To complete the picture, only if Item autoupdate is enabled/default will it go on to look at channel policy (if any) and take that into into account.
Hey there again!
Thanks for the additional info, @rossko57. After playing around a little bit more I’m under the impression, that forcing the autoupdate also seems to be a bad practice. I’ve experiences some inconsistencies with the group states, especially when mixing items with forced autoupdate and default autoupdate. However, it’s a bit difficult to really identify the cause, because I’m not sure if something very basic is messed up with my items though.
@chris, did you maybe had any chance to have a look into the logs?
Don’t see any reason for that. Group states are derived from member states; it matters not what mechanism changes member states.
I agree. That’s why I want to decouple this from the original issue, because I believe it’s caused by something unrelated.
Hi @rossko57 and @chris,
I had the time to do a little more research here and I came up with another observation.
I can clearly differentiate the “working” devices from the “not working” devices by the fact that the latter ones fail to be initialized correctly.
So, when I, via Paper UI and the thing configuration page, trigger the “Initialize device” switch in the settings, I do get an error “Error opening device level controls” in the logs. This occurs for these things where the linked items do not update their states.
There is no such error in the logs for these things where the linked items do update their states.
Here you go with debug logs for the “not working” device initialization:
2020-07-26 15:28:46.199 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'Investigation.items'
2020-07-26 15:29:52.905 [ome.event.ItemCommandEvent] - Item 'TestItem_NotWorking' received command 27
2020-07-26 15:29:58.909 [ome.event.ItemCommandEvent] - Item 'TestItem_NotWorking' received command 100
2020-07-26 15:30:08.698 [me.event.ThingUpdatedEvent] - Thing 'zigbee:device:0137F59F:0017880103d08243' has been updated.
2020-07-26 15:30:09.906 [ERROR] [converter.ZigBeeConverterSwitchLevel] - 0017880103D08243: Error opening device level controls
2020-07-26 15:30:09.909 [INFO ] [ng.zigbee.handler.ZigBeeThingHandler] - 0017880103D08243: Channel zigbee:device:0137F59F:0017880103d08243:0017880103D08243_11_dimmer failed to initialise device
2020-07-26 15:30:36.128 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D00015C55E3: Polling...
2020-07-26 15:30:41.954 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0104, clusterId=0019, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=38], lastHopLqi=255, lastHopRssi=-42, sender=65E6, bindingIndex=255, addressIndex=255, messageContents=01 DA 01 00 9D 11 01 11 12 14 03 17]
2020-07-26 15:30:41.961 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=65E6/1, destinationAddress=0000/1, profile=0104, cluster=0019, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=38, rssi=-42, lqi=FF, payload=01 DA 01 00 9D 11 01 11 12 14 03 17]
2020-07-26 15:30:41.963 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=218, commandId=1]
2020-07-26 15:30:41.966 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: QueryNextImageCommand [Ota Upgrade: 65E6/1 -> 0000/1, cluster=0019, TID=DA, fieldControl=0, manufacturerCode=4509, imageType=4353, fileVersion=386077714, hardwareVersion=null]
2020-07-26 15:30:41.968 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: QueryNextImageCommand [Ota Upgrade: 65E6/1 -> 0000/1, cluster=0019, TID=DA, fieldControl=0, manufacturerCode=4509, imageType=4353, fileVersion=386077714, hardwareVersion=null]
2020-07-26 15:30:41.972 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 00158D000315530D: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=00158D000315530D queueTime=0, state=WAITING, sendCnt=0, command=QueryNextImageResponse [Ota Upgrade: 0000/0 -> 65E6/1, cluster=0019, TID=DA, status=NO_IMAGE_AVAILABLE, manufacturerCode=4509, imageType=4353, fileVersion=386077714, imageSize=0]]
2020-07-26 15:30:41.975 [DEBUG] [transaction.ZigBeeTransactionManager] - 65E6/1: Sending ZigBeeTransaction [ieeeAddress=00158D000315530D queueTime=4, state=WAITING, sendCnt=0, command=QueryNextImageResponse [Ota Upgrade: 0000/0 -> 65E6/1, cluster=0019, TID=DA, status=NO_IMAGE_AVAILABLE, manufacturerCode=4509, imageType=4353, fileVersion=386077714, imageSize=0]]
2020-07-26 15:30:41.977 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2020-07-26 15:30:41.980 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: QueryNextImageResponse [Ota Upgrade: 0000/0 -> 65E6/1, cluster=0019, TID=DA, status=NO_IMAGE_AVAILABLE, manufacturerCode=4509, imageType=4353, fileVersion=386077714, imageSize=0]
2020-07-26 15:30:41.983 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=218, commandId=2]
2020-07-26 15:30:41.986 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=65E6/1, profile=0104, cluster=0019, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=D0, rssi=--, lqi=--, payload=19 DA 02 98]
2020-07-26 15:30:42.000 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=12]
2020-07-26 15:30:42.049 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=65E6, apsFrame=EmberApsFrame [profileId=0104, clusterId=0019, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=12], messageTag=DA, status=EMBER_SUCCESS, messageContents=]
2020-07-26 15:30:42.051 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=DA state=RX_ACK
2020-07-26 15:30:42.053 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=DA, state=RX_ACK, outstanding=1
2020-07-26 15:30:42.055 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=00158D000315530D queueTime=84, state=COMPLETE, sendCnt=1, command=QueryNextImageResponse [Ota Upgrade: 0000/0 -> 65E6/1, cluster=0019, TID=DA, status=NO_IMAGE_AVAILABLE, manufacturerCode=4509, imageType=4353, fileVersion=386077714, imageSize=0]]
2020-07-26 15:30:42.057 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2020-07-26 15:30:42.059 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 00158D000315530D: transactionComplete COMPLETE 0
2020-07-26 15:30:42.061 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state updated: TID DA -> RX_ACK == COMPLETE
2020-07-26 15:30:48.650 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0104, clusterId=0019, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=1F], lastHopLqi=255, lastHopRssi=-41, sender=D30F, bindingIndex=255, addressIndex=255, messageContents=01 1A 01 00 9D 11 01 11 12 14 03 17]
2020-07-26 15:30:48.653 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=D30F/1, destinationAddress=0000/1, profile=0104, cluster=0019, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=1F, rssi=-41, lqi=FF, payload=01 1A 01 00 9D 11 01 11 12 14 03 17]
2020-07-26 15:30:48.655 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=26, commandId=1]
2020-07-26 15:30:48.657 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: QueryNextImageCommand [Ota Upgrade: D30F/1 -> 0000/1, cluster=0019, TID=1A, fieldControl=0, manufacturerCode=4509, imageType=4353, fileVersion=386077714, hardwareVersion=null]
2020-07-26 15:30:48.659 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: QueryNextImageCommand [Ota Upgrade: D30F/1 -> 0000/1, cluster=0019, TID=1A, fieldControl=0, manufacturerCode=4509, imageType=4353, fileVersion=386077714, hardwareVersion=null]
2020-07-26 15:30:48.663 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 00158D00015C4E6C: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=00158D00015C4E6C queueTime=0, state=WAITING, sendCnt=0, command=QueryNextImageResponse [Ota Upgrade: 0000/0 -> D30F/1, cluster=0019, TID=1A, status=NO_IMAGE_AVAILABLE, manufacturerCode=4509, imageType=4353, fileVersion=386077714, imageSize=0]]
2020-07-26 15:30:48.666 [DEBUG] [transaction.ZigBeeTransactionManager] - D30F/1: Sending ZigBeeTransaction [ieeeAddress=00158D00015C4E6C queueTime=3, state=WAITING, sendCnt=0, command=QueryNextImageResponse [Ota Upgrade: 0000/0 -> D30F/1, cluster=0019, TID=1A, status=NO_IMAGE_AVAILABLE, manufacturerCode=4509, imageType=4353, fileVersion=386077714, imageSize=0]]
2020-07-26 15:30:48.668 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2020-07-26 15:30:48.671 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: QueryNextImageResponse [Ota Upgrade: 0000/0 -> D30F/1, cluster=0019, TID=1A, status=NO_IMAGE_AVAILABLE, manufacturerCode=4509, imageType=4353, fileVersion=386077714, imageSize=0]
2020-07-26 15:30:48.674 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=26, commandId=2]
2020-07-26 15:30:48.676 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=D30F/1, profile=0104, cluster=0019, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=D1, rssi=--, lqi=--, payload=19 1A 02 98]
2020-07-26 15:30:48.691 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=13]
2020-07-26 15:30:48.785 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteErrorHandler [networkId=0, status=EMBER_SOURCE_ROUTE_FAILURE, target=D30F]
2020-07-26 15:30:48.809 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=D30F, apsFrame=EmberApsFrame [profileId=0104, clusterId=0019, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=13], messageTag=1A, status=EMBER_SUCCESS, messageContents=]
2020-07-26 15:30:48.811 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=1A state=RX_ACK
2020-07-26 15:30:48.813 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=1A, state=RX_ACK, outstanding=1
2020-07-26 15:30:48.816 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=00158D00015C4E6C queueTime=153, state=COMPLETE, sendCnt=1, command=QueryNextImageResponse [Ota Upgrade: 0000/0 -> D30F/1, cluster=0019, TID=1A, status=NO_IMAGE_AVAILABLE, manufacturerCode=4509, imageType=4353, fileVersion=386077714, imageSize=0]]
2020-07-26 15:30:48.818 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2020-07-26 15:30:48.820 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 00158D00015C4E6C: transactionComplete COMPLETE 0
2020-07-26 15:30:48.822 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state updated: TID 1A -> RX_ACK == COMPLETE
2020-07-26 15:30:56.455 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 0017880103D08243: Configuration received: {zigbee_macaddress=0017880103D08243, zigbee_initialise_device=true}
2020-07-26 15:30:56.457 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 0017880103D08243: Configuration update: Ignored zigbee_macaddress as no change
2020-07-26 15:30:56.459 [DEBUG] [e.internal.ZigBeeDeviceConfigHandler] - Configuration update: Ignored zigbee_macaddress as no change
2020-07-26 15:30:56.464 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 0017880103D08243: Configuration updated: Reinitialise device
2020-07-26 15:30:56.466 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 0017880103D08243: Initializing device
2020-07-26 15:30:56.467 [me.event.ThingUpdatedEvent] - Thing 'zigbee:device:0137F59F:0017880103d08243' has been updated.
2020-07-26 15:30:56.469 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 0017880103D08243: Initializing channel zigbee:device:0137F59F:0017880103d08243:0017880103D08243_11_colortemperature with org.openhab.binding.zigbee.internal.converter.ZigBeeConverterColorTemperature@bb857b
2020-07-26 15:30:56.472 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0017880103D08243: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=0, state=WAITING, sendCnt=0, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=--, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=768, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:56.475 [DEBUG] [transaction.ZigBeeTransactionManager] - CB64/0: Sending ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=3, state=WAITING, sendCnt=0, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=6D, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=768, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:56.476 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2020-07-26 15:30:56.479 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: BindRequest [0000/0 -> CB64/0, cluster=0021, TID=6D, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=768, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]
2020-07-26 15:30:56.482 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=CB64/0, profile=0000, cluster=0021, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=D2, rssi=--, lqi=--, payload=6D 43 82 D0 03 01 88 17 00 0B 00 03 03 46 F6 3A 0D 00 6F 0D 00 01]
2020-07-26 15:30:56.497 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=14]
2020-07-26 15:30:56.546 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=CB64, sourceEui=0017880103D08243, lastHopLqi=255, lastHopRssi=-41, relayList=F753]
2020-07-26 15:30:56.629 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=CB64, apsFrame=EmberApsFrame [profileId=0000, clusterId=0021, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=14], messageTag=6D, status=EMBER_SUCCESS, messageContents=]
2020-07-26 15:30:56.630 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=6D state=RX_ACK
2020-07-26 15:30:56.631 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=6D, state=RX_ACK, outstanding=1
2020-07-26 15:30:56.632 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state updated: TID 6D -> RX_ACK == ACKED
2020-07-26 15:30:56.651 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=CB64, sourceEui=0017880103D08243, lastHopLqi=255, lastHopRssi=-42, relayList=F753]
2020-07-26 15:30:56.716 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=8021, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=93], lastHopLqi=255, lastHopRssi=-41, sender=CB64, bindingIndex=255, addressIndex=255, messageContents=6D 00]
2020-07-26 15:30:56.717 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=CB64/0, destinationAddress=0000/0, profile=0000, cluster=8021, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=93, rssi=-41, lqi=FF, payload=6D 00]
2020-07-26 15:30:56.719 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: BindResponse [CB64/0 -> 0000/0, cluster=8021, TID=6D, status=SUCCESS]
2020-07-26 15:30:56.720 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: BindResponse [CB64/0 -> 0000/0, cluster=8021, TID=6D, status=SUCCESS]
2020-07-26 15:30:56.722 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: BindResponse [CB64/0 -> 0000/0, cluster=8021, TID=6D, status=SUCCESS] ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=250, state=ACKED, sendCnt=1, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=6D, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=768, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:56.723 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=252, state=COMPLETE, sendCnt=1, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=6D, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=768, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:56.723 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0017880103D08243: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=0, state=WAITING, sendCnt=0, command=ConfigureReportingCommand [Color Control: 0000/0 -> CB64/11, cluster=0300, TID=--, records=[AttributeReportingConfigurationRecord [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=7, direction=0, minimumReportingInterval=1, maximumReportingInterval=7200, reportableChange=1]]]]
2020-07-26 15:30:56.725 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2020-07-26 15:30:56.725 [DEBUG] [transaction.ZigBeeTransactionManager] - CB64/11: Sending ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=2, state=WAITING, sendCnt=0, command=ConfigureReportingCommand [Color Control: 0000/0 -> CB64/11, cluster=0300, TID=6E, records=[AttributeReportingConfigurationRecord [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=7, direction=0, minimumReportingInterval=1, maximumReportingInterval=7200, reportableChange=1]]]]
2020-07-26 15:30:56.727 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2020-07-26 15:30:56.729 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ConfigureReportingCommand [Color Control: 0000/0 -> CB64/11, cluster=0300, TID=6E, records=[AttributeReportingConfigurationRecord [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=7, direction=0, minimumReportingInterval=1, maximumReportingInterval=7200, reportableChange=1]]]
2020-07-26 15:30:56.731 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=110, commandId=6]
2020-07-26 15:30:56.732 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=CB64/11, profile=0104, cluster=0300, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=D3, rssi=--, lqi=--, payload=00 6E 06 00 07 00 21 01 00 20 1C 01 00]
2020-07-26 15:30:56.735 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0017880103D08243: transactionComplete COMPLETE 1
2020-07-26 15:30:56.747 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=15]
2020-07-26 15:30:56.796 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=CB64, sourceEui=0017880103D08243, lastHopLqi=255, lastHopRssi=-42, relayList=F753]
2020-07-26 15:30:56.879 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=CB64, apsFrame=EmberApsFrame [profileId=0104, clusterId=0300, sourceEndpoint=1, destinationEndpoint=11, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=15], messageTag=6E, status=EMBER_SUCCESS, messageContents=]
2020-07-26 15:30:56.880 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=6E state=RX_ACK
2020-07-26 15:30:56.881 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=6E, state=RX_ACK, outstanding=1
2020-07-26 15:30:56.882 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state updated: TID 6E -> RX_ACK == ACKED
2020-07-26 15:30:56.901 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=CB64, sourceEui=0017880103D08243, lastHopLqi=255, lastHopRssi=-42, relayList=F753]
2020-07-26 15:30:56.969 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0104, clusterId=0300, sourceEndpoint=11, destinationEndpoint=1, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=94], lastHopLqi=255, lastHopRssi=-41, sender=CB64, bindingIndex=255, addressIndex=255, messageContents=18 6E 0B 06 82]
2020-07-26 15:30:56.972 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=CB64/11, destinationAddress=0000/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=94, rssi=-41, lqi=FF, payload=18 6E 0B 06 82]
2020-07-26 15:30:56.973 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=110, commandId=11]
2020-07-26 15:30:56.976 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: DefaultResponse [Color Control: CB64/11 -> 0000/1, cluster=0300, TID=6E, commandIdentifier=6, statusCode=UNSUP_GENERAL_COMMAND]
2020-07-26 15:30:56.978 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [Color Control: CB64/11 -> 0000/1, cluster=0300, TID=6E, commandIdentifier=6, statusCode=UNSUP_GENERAL_COMMAND]
2020-07-26 15:30:56.981 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [Color Control: CB64/11 -> 0000/1, cluster=0300, TID=6E, commandIdentifier=6, statusCode=UNSUP_GENERAL_COMMAND] ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=257, state=ACKED, sendCnt=1, command=ConfigureReportingCommand [Color Control: 0000/0 -> CB64/11, cluster=0300, TID=6E, records=[AttributeReportingConfigurationRecord [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=7, direction=0, minimumReportingInterval=1, maximumReportingInterval=7200, reportableChange=1]]]]
2020-07-26 15:30:56.984 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=260, state=COMPLETE, sendCnt=1, command=ConfigureReportingCommand [Color Control: 0000/0 -> CB64/11, cluster=0300, TID=6E, records=[AttributeReportingConfigurationRecord [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=7, direction=0, minimumReportingInterval=1, maximumReportingInterval=7200, reportableChange=1]]]]
2020-07-26 15:30:56.984 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0017880103D08243: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=0, state=WAITING, sendCnt=0, command=ConfigureReportingCommand [Color Control: 0000/0 -> CB64/11, cluster=0300, TID=--, records=[AttributeReportingConfigurationRecord [attributeDataType=ENUMERATION_8_BIT, attributeIdentifier=8, direction=0, minimumReportingInterval=1, maximumReportingInterval=7200]]]]
2020-07-26 15:30:56.986 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2020-07-26 15:30:56.988 [DEBUG] [transaction.ZigBeeTransactionManager] - CB64/11: Sending ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=4, state=WAITING, sendCnt=0, command=ConfigureReportingCommand [Color Control: 0000/0 -> CB64/11, cluster=0300, TID=6F, records=[AttributeReportingConfigurationRecord [attributeDataType=ENUMERATION_8_BIT, attributeIdentifier=8, direction=0, minimumReportingInterval=1, maximumReportingInterval=7200]]]]
2020-07-26 15:30:56.991 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2020-07-26 15:30:56.994 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ConfigureReportingCommand [Color Control: 0000/0 -> CB64/11, cluster=0300, TID=6F, records=[AttributeReportingConfigurationRecord [attributeDataType=ENUMERATION_8_BIT, attributeIdentifier=8, direction=0, minimumReportingInterval=1, maximumReportingInterval=7200]]]
2020-07-26 15:30:56.997 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=111, commandId=6]
2020-07-26 15:30:57.001 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=CB64/11, profile=0104, cluster=0300, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=D4, rssi=--, lqi=--, payload=00 6F 06 00 08 00 30 01 00 20 1C]
2020-07-26 15:30:57.004 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0017880103D08243: transactionComplete COMPLETE 1
2020-07-26 15:30:57.015 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=16]
2020-07-26 15:30:57.069 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=CB64, sourceEui=0017880103D08243, lastHopLqi=255, lastHopRssi=-41, relayList=F753]
2020-07-26 15:30:57.149 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=CB64, apsFrame=EmberApsFrame [profileId=0104, clusterId=0300, sourceEndpoint=1, destinationEndpoint=11, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=16], messageTag=6F, status=EMBER_SUCCESS, messageContents=]
2020-07-26 15:30:57.151 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=6F state=RX_ACK
2020-07-26 15:30:57.153 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=6F, state=RX_ACK, outstanding=1
2020-07-26 15:30:57.156 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state updated: TID 6F -> RX_ACK == ACKED
2020-07-26 15:30:57.172 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=CB64, sourceEui=0017880103D08243, lastHopLqi=255, lastHopRssi=-41, relayList=F753]
2020-07-26 15:30:57.230 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0104, clusterId=0300, sourceEndpoint=11, destinationEndpoint=1, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=95], lastHopLqi=255, lastHopRssi=-41, sender=CB64, bindingIndex=255, addressIndex=255, messageContents=18 6F 0B 06 82]
2020-07-26 15:30:57.232 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=CB64/11, destinationAddress=0000/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=95, rssi=-41, lqi=FF, payload=18 6F 0B 06 82]
2020-07-26 15:30:57.235 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=111, commandId=11]
2020-07-26 15:30:57.237 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: DefaultResponse [Color Control: CB64/11 -> 0000/1, cluster=0300, TID=6F, commandIdentifier=6, statusCode=UNSUP_GENERAL_COMMAND]
2020-07-26 15:30:57.240 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [Color Control: CB64/11 -> 0000/1, cluster=0300, TID=6F, commandIdentifier=6, statusCode=UNSUP_GENERAL_COMMAND]
2020-07-26 15:30:57.242 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [Color Control: CB64/11 -> 0000/1, cluster=0300, TID=6F, commandIdentifier=6, statusCode=UNSUP_GENERAL_COMMAND] ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=258, state=ACKED, sendCnt=1, command=ConfigureReportingCommand [Color Control: 0000/0 -> CB64/11, cluster=0300, TID=6F, records=[AttributeReportingConfigurationRecord [attributeDataType=ENUMERATION_8_BIT, attributeIdentifier=8, direction=0, minimumReportingInterval=1, maximumReportingInterval=7200]]]]
2020-07-26 15:30:57.245 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=262, state=COMPLETE, sendCnt=1, command=ConfigureReportingCommand [Color Control: 0000/0 -> CB64/11, cluster=0300, TID=6F, records=[AttributeReportingConfigurationRecord [attributeDataType=ENUMERATION_8_BIT, attributeIdentifier=8, direction=0, minimumReportingInterval=1, maximumReportingInterval=7200]]]]
2020-07-26 15:30:57.246 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 0017880103D08243: Initializing channel zigbee:device:0137F59F:0017880103d08243:0017880103D08243_11_dimmer with org.openhab.binding.zigbee.internal.converter.ZigBeeConverterSwitchLevel@476977
2020-07-26 15:30:57.248 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2020-07-26 15:30:57.250 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0017880103D08243: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=0, state=WAITING, sendCnt=0, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=--, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=8, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:57.254 [DEBUG] [transaction.ZigBeeTransactionManager] - CB64/0: Sending ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=4, state=WAITING, sendCnt=0, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=70, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=8, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:57.257 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2020-07-26 15:30:57.260 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: BindRequest [0000/0 -> CB64/0, cluster=0021, TID=70, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=8, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]
2020-07-26 15:30:57.263 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=CB64/0, profile=0000, cluster=0021, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=D5, rssi=--, lqi=--, payload=70 43 82 D0 03 01 88 17 00 0B 08 00 03 46 F6 3A 0D 00 6F 0D 00 01]
2020-07-26 15:30:57.266 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0017880103D08243: transactionComplete COMPLETE 1
2020-07-26 15:30:57.281 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=17]
2020-07-26 15:30:57.328 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=CB64, sourceEui=0017880103D08243, lastHopLqi=255, lastHopRssi=-42, relayList=F753]
2020-07-26 15:30:57.395 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=CB64, apsFrame=EmberApsFrame [profileId=0000, clusterId=0021, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=17], messageTag=70, status=EMBER_SUCCESS, messageContents=]
2020-07-26 15:30:57.397 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=70 state=RX_ACK
2020-07-26 15:30:57.399 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=70, state=RX_ACK, outstanding=1
2020-07-26 15:30:57.401 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state updated: TID 70 -> RX_ACK == ACKED
2020-07-26 15:30:57.422 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=CB64, sourceEui=0017880103D08243, lastHopLqi=255, lastHopRssi=-41, relayList=F753]
2020-07-26 15:30:57.489 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=8021, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=96], lastHopLqi=255, lastHopRssi=-41, sender=CB64, bindingIndex=255, addressIndex=255, messageContents=70 8C]
2020-07-26 15:30:57.491 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=CB64/0, destinationAddress=0000/0, profile=0000, cluster=8021, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=96, rssi=-41, lqi=FF, payload=70 8C]
2020-07-26 15:30:57.493 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: BindResponse [CB64/0 -> 0000/0, cluster=8021, TID=70, status=TABLE_FULL]
2020-07-26 15:30:57.495 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: BindResponse [CB64/0 -> 0000/0, cluster=8021, TID=70, status=TABLE_FULL]
2020-07-26 15:30:57.498 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: BindResponse [CB64/0 -> 0000/0, cluster=8021, TID=70, status=TABLE_FULL] ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=248, state=ACKED, sendCnt=1, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=70, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=8, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:57.501 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=251, state=COMPLETE, sendCnt=1, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=70, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=8, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:57.501 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - 0017880103D08243: Failed to bind level control cluster
2020-07-26 15:30:57.503 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2020-07-26 15:30:57.504 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0017880103D08243: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=0, state=WAITING, sendCnt=0, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=--, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=6, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:57.509 [DEBUG] [transaction.ZigBeeTransactionManager] - CB64/0: Sending ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=5, state=WAITING, sendCnt=0, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=71, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=6, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:57.511 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2020-07-26 15:30:57.515 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: BindRequest [0000/0 -> CB64/0, cluster=0021, TID=71, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=6, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]
2020-07-26 15:30:57.518 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=CB64/0, profile=0000, cluster=0021, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=D6, rssi=--, lqi=--, payload=71 43 82 D0 03 01 88 17 00 0B 06 00 03 46 F6 3A 0D 00 6F 0D 00 01]
2020-07-26 15:30:57.521 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0017880103D08243: transactionComplete COMPLETE 1
2020-07-26 15:30:57.536 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=18]
2020-07-26 15:30:57.591 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=CB64, sourceEui=0017880103D08243, lastHopLqi=255, lastHopRssi=-42, relayList=F753]
2020-07-26 15:30:57.668 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=CB64, apsFrame=EmberApsFrame [profileId=0000, clusterId=0021, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=18], messageTag=71, status=EMBER_SUCCESS, messageContents=]
2020-07-26 15:30:57.672 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=71 state=RX_ACK
2020-07-26 15:30:57.674 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=71, state=RX_ACK, outstanding=1
2020-07-26 15:30:57.676 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state updated: TID 71 -> RX_ACK == ACKED
2020-07-26 15:30:57.691 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteRecordHandler [networkId=0, source=CB64, sourceEui=0017880103D08243, lastHopLqi=255, lastHopRssi=-41, relayList=F753]
2020-07-26 15:30:57.758 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=8021, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=97], lastHopLqi=255, lastHopRssi=-41, sender=CB64, bindingIndex=255, addressIndex=255, messageContents=71 8C]
2020-07-26 15:30:57.761 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=CB64/0, destinationAddress=0000/0, profile=0000, cluster=8021, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=97, rssi=-41, lqi=FF, payload=71 8C]
2020-07-26 15:30:57.763 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: BindResponse [CB64/0 -> 0000/0, cluster=8021, TID=71, status=TABLE_FULL]
2020-07-26 15:30:57.765 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: BindResponse [CB64/0 -> 0000/0, cluster=8021, TID=71, status=TABLE_FULL]
2020-07-26 15:30:57.768 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: BindResponse [CB64/0 -> 0000/0, cluster=8021, TID=71, status=TABLE_FULL] ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=264, state=ACKED, sendCnt=1, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=71, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=6, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:57.770 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=0017880103D08243 queueTime=266, state=COMPLETE, sendCnt=1, command=BindRequest [0000/0 -> CB64/0, cluster=0021, TID=71, srcAddress=0017880103D08243, srcEndpoint=11, bindCluster=6, dstAddrMode=3, dstAddress=000D6F000D3AF646, dstEndpoint=1]]
2020-07-26 15:30:57.772 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2020-07-26 15:30:57.770 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - 0017880103D08243: Failed to bind on off control cluster
2020-07-26 15:30:57.774 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 0017880103D08243: transactionComplete COMPLETE 0
2020-07-26 15:30:57.775 [ERROR] [converter.ZigBeeConverterSwitchLevel] - 0017880103D08243: Error opening device level controls
2020-07-26 15:30:57.778 [INFO ] [ng.zigbee.handler.ZigBeeThingHandler] - 0017880103D08243: Channel zigbee:device:0137F59F:0017880103d08243:0017880103D08243_11_dimmer failed to initialise device
I also did some searching around and found this thread (Zigbee Binding fails to initialize dimmer) and an corresponding issue (Binding should NOT require an endpoint with Level Control to also support the OnOff cluster. · Issue #522 · openhab/org.openhab.binding.zigbee · GitHub).
Maybe there’s some connection? Do you have any idea on this one?
Thanks and best!
For reference if anyone stumbles over this thread. The issue was addressed here and the root cause identified:
Currently the only way to solve it is to use an explicit autoupdate=true on the effected items. You may find comprehensive information on the why in the mentioned thread.
