Iβm updating my unstable release (core and addons ) from openhab_3.3.0~S2801 to the newer versione, but after installing the package via atp update and apt upgrade command, the sistem starts, openhab UI is reacheble but nothing happens
i received a lot of error about missing file jar and every 15 seconds thee following warning
2022-03-15 12:43:53.629 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 12:43:53.630 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
I have already cleaned cache, restared several times manually put addons .kar file in /user/share/openah/addons folder, Try to install missing bindings from UI but also this operation fails.
updating from snapshot openhab_3.3.0~S2801 to openhab_3.3.0~S2802 but the same for the following snapshot:
openhab_3.3.0~S2803,
openhab_3.3.0~S2804,
openhab_3.3.0~S2805
downgrading from openhab_3.3.0~S2805 to openhab_3.3.0~S2801 it start again to works
You are currently running an older 3.3.0-SNAPSHOT, correct? I would suggest to clean cache and temp and restart (on the version that is working) and see if the updates repos are shown.
And please (before cleaning cache) show the output of
openhab> list -s org.openhab.core
START LEVEL 100 , List Threshold: 50
ID β State β Lvl β Version β Symbolic name
βββββΌβββββββββΌββββββΌβββββββββββββββββββββΌββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
154 β Active β 80 β 3.2.0.202109160627 β org.openhab.core
openhab>
Iβm going to clean cache,
What is the path for temp folder?
Repository Installation Manual Installation (according to guide)
openHAB application /usr/share/openhab /opt/openhab
Additional add-on files /usr/share/openhab/addons /opt/openhab/addons
Site configuration /etc/openhab /opt/openhab/conf
Log files /var/log/openhab /opt/openhab/userdata/logs
Userdata like rrd4j databases /var/lib/openhab /opt/openhab/userdata
Backups folder /var/lib/openhab/backups /opt/openhab/backups
Service configuration /etc/default/openhab (not preconfigured)
after clean cache, after command sudo apt remove openhab and after reinstalling the last working snapshot (openhab_3.3.0~S2801 ) ,
this is the result of command feature:repo-list
Iβm update to latest snapshotβ¦and there is the same error
and this is the result of command list -s org.openhab.core
150 β Active β 80 β 3.3.0.202203150301 β org.openhab.core
openhab>
I also have the same error with the latest docker image:
2022-03-15 18:04:51.601 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 18:04:51.602 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
==> /logs/openhab.log <==
2022-03-15 18:05:06.603 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 18:05:06.604 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
2022-03-15 18:05:21.606 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 18:05:21.607 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
2022-03-15 18:05:36.608 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 18:05:36.609 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
2022-03-15 18:05:51.610 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 18:05:51.611 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
2022-03-15 18:06:06.612 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 18:06:06.612 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
2022-03-15 18:06:21.613 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 19:09:54.887 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 19:09:54.887 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
2022-03-15 19:10:09.888 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 19:10:09.888 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
2022-03-15 19:10:24.888 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 19:10:24.889 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
2022-03-15 19:10:39.889 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2022-03-15 19:10:39.890 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
and NO it doesnβt work, all thinghs are not initialiazed and items are null
the only line in the log are the warnings and the info I posted above.
furthermore with commands bundle:list it seems that addons are not installed
openhab> bundle:list
ID β State β Lvl β Version β Name
βββββΌβββββββββΌββββββΌβββββββββββββββββββββββββΌββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
29 β Active β 80 β 2.12.5 β Jackson-annotations
30 β Active β 80 β 2.12.5 β Jackson-core
31 β Active β 80 β 2.12.5 β jackson-databind
32 β Active β 80 β 2.12.5 β Jackson-dataformat-YAML
33 β Active β 80 β 2.12.5 β Jackson datatype: JSR310
34 β Active β 80 β 6.2.6 β Woodstox
35 β Active β 80 β 2.8.9 β Gson
36 β Active β 80 β 30.1.0.jre β Guava: Google Core Libraries for Java
37 β Active β 80 β 1.0.1 β Guava InternalFutureFailureAccess and InternalFutures
38 β Active β 80 β 5.0.1.v20210324-2015 β Google Guice - Core Library
40 β Active β 80 β 4.8.138.v20211212-1642 β ClassGraph
41 β Active β 80 β 2.1.9 β swagger-annotations
42 β Active β 80 β 2.1.9 β swagger-core
43 β Active β 80 β 2.1.9 β swagger-integration
44 β Active β 80 β 2.1.9 β swagger-jaxrs2
45 β Active β 80 β 2.1.9 β swagger-models
46 β Active β 80 β 2.0.2 β Jakarta Bean Validation API
48 β Active β 80 β 2.3.3 β Jakarta XML Web Services API
51 β Active β 80 β 3.5.7 β JmDNS
52 β Active β 80 β 2.1.3 β Units of Measurement API
54 β Active β 80 β 0.5.10 β Jollyday
55 β Active β 80 β 3.2.0.v201101311130 β ANTLR Runtime
56 β Active β 80 β 1.0.0.v201105210816 β Aopalliance Plug-in
57 β Active β 80 β 1.2.2 β org.apache.aries.component-dsl.component-dsl
58 β Active β 80 β 1.0.1 β Apache Aries JAX-RS Specification API
59 β Active β 80 β 2.0.0 β Apache Aries JAX-RS Whiteboard
61 β Active β 80 β 3.12.0 β Apache Commons Lang
62 β Active β 80 β 3.4.5 β Apache CXF Core
63 β Active β 80 β 3.4.5 β Apache CXF Runtime JAX-RS Frontend
64 β Active β 80 β 3.4.5 β Apache CXF JAX-RS Client
65 β Active β 80 β 3.4.5 β Apache CXF JAX-RS Server-Side Events Support
66 β Active β 80 β 3.4.5 β Apache CXF Runtime Security functionality
67 β Active β 80 β 3.4.5 β Apache CXF Runtime HTTP Transport
76 β Active β 80 β 4.3.6 β Apache Karaf :: OSGi Services :: Event
87 β Active β 80 β 1.0.0.2 β Apache ServiceMix :: Bundles :: javax.inject
95 β Active β 80 β 2.2.5 β XmlSchema Core
96 β Active β 80 β 4.20.0 β Apache XBean :: OSGI Bundle Utilities
97 β Active β 80 β 4.20.0 β Apache XBean :: Classpath Resource Finder
98 β Active β 80 β 0.7.7 β jose4j
99 β Active β 80 β 2.17.0.v20190920-0401 β EMF Common
100 β Active β 80 β 2.20.0.v20190920-0401 β EMF Ecore
101 β Active β 80 β 2.14.0.v20190528-0725 β EMF Change Model
102 β Active β 80 β 2.16.0.v20190528-0725 β EMF XML/XMI Persistence
103 β Active β 80 β 3.13.0.v20200828-1034 β Common Eclipse Runtime
132 β Active β 80 β 0.12.0.v20210402-1305 β org.eclipse.lsp4j
133 β Active β 80 β 0.12.0.v20210402-1305 β org.eclipse.lsp4j.jsonrpc
134 β Active β 80 β 2.26.0.v20220228-0748 β Xtend Runtime Library
135 β Active β 80 β 2.26.0.v20220228-0748 β Xtend Macro Interfaces
136 β Active β 80 β 2.26.0.v20220228-0751 β Xtext
137 β Active β 80 β 2.26.0.v20220228-0758 β Xtext Common Types
138 β Active β 80 β 2.26.0.v20220228-0751 β Xtext IDE Core
139 β Active β 80 β 2.26.0.v20220228-0751 β Xtext Utility
140 β Active β 80 β 2.26.0.v20220228-0758 β Xbase Model
141 β Active β 80 β 2.26.0.v20220228-0758 β Xbase Generic IDE Services
142 β Active β 80 β 2.26.0.v20220228-0748 β Xbase Runtime Library
146 β Active β 80 β 9.2.0 β org.objectweb.asm.commons
147 β Active β 80 β 9.2.0 β org.objectweb.asm.tree
148 β Active β 80 β 9.2.0 β org.objectweb.asm.tree.analysis
149 β Active β 80 β 9.2.0 β org.objectweb.asm.util
150 β Active β 80 β 3.3.0.202203150301 β openHAB Core :: Bundles :: Core
151 β Active β 80 β 3.3.0.202203150311 β openHAB Core :: Bundles :: Marketplace Add-on Services
152 β Active β 80 β 3.3.0.202203150311 β openHAB Core :: Bundles :: Community Marketplace Add-on Service :: Karaf
153 β Active β 80 β 3.3.0.202203150304 β openHAB Core :: Bundles :: Audio
154 β Active β 80 β 3.3.0.202203150303 β openHAB Core :: Bundles :: JAAS Authentication
155 β Active β 80 β 3.3.0.202203150304 β openHAB Core :: Bundles :: OAuth2Client
156 β Active β 80 β 3.3.0.202203150306 β openHAB Core :: Bundles :: Automation
157 β Active β 80 β 3.3.0.202203150310 β openHAB Core :: Bundles :: Automation Media Modules
158 β Active β 80 β 3.3.0.202203150308 β openHAB Core :: Bundles :: Automation Script Modules
159 β Active β 80 β 3.3.0.202203150310 β openHAB Core :: Bundles :: Automation Script RuleSupport
160 β Active β 80 β 3.3.0.202203150308 β openHAB Core :: Bundles :: Automation REST API
161 β Active β 80 β 3.3.0.202203150306 β openHAB Core :: Bundles :: Binding XML
162 β Active β 80 β 3.3.0.202203150303 β openHAB Core :: Bundles :: Configuration Core
163 β Active β 80 β 3.3.0.202203150306 β openHAB Core :: Bundles :: Configuration Discovery
164 β Active β 80 β 3.3.0.202203150309 β openHAB Core :: Bundles :: Configuration mDNS Discovery
165 β Active β 80 β 3.3.0.202203150305 β openHAB Core :: Bundles :: Configuration Dispatcher
166 β Active β 75 β 3.3.0.202203150304 β openHAB Core :: Bundles :: Configuration XML
167 β Active β 80 β 3.3.0.202203150304 β openHAB Core :: Bundles :: Ephemeris
168 β Active β 80 β 3.3.0.202203150304 β openHAB Core :: Bundles :: ID
169 β Active β 80 β 3.3.0.202203150302 β openHAB Core :: Bundles :: Console
170 β Active β 80 β 3.3.0.202203150303 β openHAB Core :: Bundles :: Console for OSGi runtime Karaf
171 β Active β 80 β 3.3.0.202203150300 β openHAB Core :: Bundles :: HTTP Interface
172 β Active β 80 β 3.3.0.202203150303 β openHAB Core :: Bundles :: HTTP Interface Authentication
174 β Active β 80 β 3.3.0.202203150308 β openHAB Core :: Bundles :: Monitor
175 β Active β 80 β 3.3.0.202203150302 β openHAB Core :: Bundles :: Network I/O
176 β Active β 80 β 3.3.0.202203150302 β openHAB Core :: Bundles :: REST Interface
177 β Active β 80 β 3.3.0.202203150306 β openHAB Core :: Bundles :: Audio REST Interface
178 β Active β 80 β 3.3.0.202203150305 β openHAB Core :: Bundles :: Authentication Support for the REST Interface
179 β Active β 80 β 3.3.0.202203150308 β openHAB Core :: Bundles :: REST Interface :: Core
180 β Active β 80 β 3.3.0.202203150309 β openHAB Core :: Bundles :: REST mDNS Announcer
181 β Active β 80 β 3.3.0.202203150310 β openHAB Core :: Bundles :: Sitemap REST Interface
182 β Active β 80 β 3.3.0.202203150306 β openHAB Core :: Bundles :: SSE Interface
183 β Active β 80 β 3.3.0.202203150304 β openHAB Core :: Bundles :: REST Interface :: Swagger 1
184 β Active β 80 β 3.3.0.202203150311 β openHAB Core :: Bundles :: UI REST Interface
185 β Active β 80 β 3.3.0.202203150307 β openHAB Core :: Bundles :: Voice REST Interface
186 β Active β 80 β 3.3.0.202203150307 β openHAB Core :: Bundles :: mDNS Service
187 β Active β 80 β 3.3.0.202203150304 β openHAB Core :: Bundles :: Karaf Integration
188 β Active β 80 β 3.3.0.202203150305 β openHAB Core :: Bundles :: Model Core
189 β Active β 80 β 3.3.0.202203150307 β openHAB Core :: Bundles :: Model Items
190 β Active β 80 β 3.3.0.202203150308 β openHAB Core :: Bundles :: Model Item IDE
191 β Active β 80 β 3.3.0.202203150308 β openHAB Core :: Bundles :: Model Items Runtime
192 β Active β 80 β 3.3.0.202203150312 β openHAB Core :: Bundles :: Language Server
193 β Active β 80 β 3.3.0.202203150307 β openHAB Core :: Bundles :: Model Persistence
194 β Active β 80 β 3.3.0.202203150309 β openHAB Core :: Bundles :: Model Persistence IDE
195 β Active β 80 β 3.3.0.202203150309 β openHAB Core :: Bundles :: Model Persistence Runtime
196 β Active β 80 β 3.3.0.202203150311 β openHAB Core :: Bundles :: Model Rules
197 β Active β 80 β 3.3.0.202203150312 β openHAB Core :: Bundles :: Model Rule IDE
198 β Active β 80 β 3.3.0.202203150312 β openHAB Core :: Bundles :: Model Rules Runtime
199 β Active β 80 β 3.3.0.202203150309 β openHAB Core :: Bundles :: Model Script
200 β Active β 80 β 3.3.0.202203150311 β openHAB Core :: Bundles :: Model Script IDE
201 β Active β 80 β 3.3.0.202203150311 β openHAB Core :: Bundles :: Model Script Runtime
202 β Active β 80 β 3.3.0.202203150307 β openHAB Core :: Bundles :: Model Sitemap
203 β Active β 80 β 3.3.0.202203150309 β openHAB Core :: Bundles :: Model Sitemap IDE
204 β Active β 80 β 3.3.0.202203150310 β openHAB Core :: Bundles :: Model Sitemap Runtime
205 β Active β 80 β 3.3.0.202203150309 β openHAB Core :: Bundles :: Model Thing
206 β Active β 80 β 3.3.0.202203150310 β openHAB Core :: Bundles :: Model Thing IDE
207 β Active β 80 β 3.3.0.202203150310 β openHAB Core :: Bundles :: Model Thing Runtime
208 β Active β 80 β 3.3.0.202203150305 β openHAB Core :: Bundles :: Persistence
209 β Active β 80 β 3.3.0.202203150303 β openHAB Core :: Bundles :: Semantics
210 β Active β 80 β 3.3.0.202203150305 β openHAB Core :: Bundles :: JSON Storage
211 β Active β 80 β 3.3.0.202203150304 β openHAB Core :: Bundles :: Thing
212 β Active β 75 β 3.3.0.202203150306 β openHAB Core :: Bundles :: Thing XML
213 β Active β 80 β 3.3.0.202203150305 β openHAB Core :: Bundles :: Transformation Service
214 β Active β 80 β 3.3.0.202203150309 β openHAB Core :: Bundles :: UI
215 β Active β 80 β 3.3.0.202203150311 β openHAB Core :: Bundles :: UI Icon Support
216 β Active β 80 β 3.3.0.202203150306 β openHAB Core :: Bundles :: Voice
217 β Active β 80 β 3.3.0.202203131216 β openHAB UI :: Bundles :: Main UI
218 β Active β 80 β 3.3.0.202203131208 β openHAB UI :: Bundles :: Icon Set :: Classic
225 β Active β 80 β 1.0.0.201802012106 β org.osgi:org.osgi.service.jaxrs
226 β Active β 80 β 1.5.0 β ThreeTen-Extra
227 β Active β 80 β 1.27.0 β SnakeYAML
228 β Active β 80 β 2.1 β SI Units
229 β Active β 80 β 2.1.0 β SI Quantities
230 β Active β 80 β 4.2.1 β Stax2 API
231 β Active β 80 β 2.1.2 β Units of Measurement Reference Implementation
232 β Active β 80 β 2.1.0 β Units of Measurement Common Library for Java
233 β Active β 80 β 1.4.19 β XStream Core
openhab>
there si the way to download an archive with all the jar files to put manually in the addons folder?
Background information: There were reports of exceptions during startup and the reason turned out to be a not fully installed .kar in the addons folder. I therefore implemented a check for that. It seems that for some yet unknown reason it fails in determining the addon folder. We need to find out whatβs wrong.
So there we have the reason: the different PID. I wonder why the PID is so different. Iβll investigate and provide a fix. For the time being, please stick with an older snapshot, there is nothing you can do at the moment. The empty directory is fine.
