Hello everyone,
I started working with openHAB a couple of days ago and in the moment I am trying to establish a MQTT connection to a Beckhoff PLC (TC3).
I have no problems on the PLC side, but openHab drives me crazy so far
I basically want to forward all openHAB items to the Beckhoff PLC.For that I created a broker, a connection and some channels.
Bridge mqtt:broker:Tc3 "TC3_Broker" [ host="192.168.0.22", port=1883, secure=false, clientID="openHAB2", username="Marcel", password="XXXXX"]
// My OBI switches with Tasmota
Thing topic Connection "TC3" {
Channels:
Type string : MyMessage "Tc3_Message" [ stateTopic="openHab/MyMessage", commandTopic="openHab/MyMessage", retained=true, postCommand=true ]
//Office
//HP-Printer
Type string : OfficePrinterStatusStatus [ commandTopic="openHab/Office/Printer/StatusStatus", retained=true, postCommand=true ]
Type number : OfficePrinterInkBlackLevel [ commandTopic="openHab/Office/Printer/InkBlackLevel", retained=true, postCommand=true ]
Type number : OfficePrinterUsageTotalCount [ commandTopic="openHab/Office/Printer/UsageTotalCount", retained=true, postCommand=true ]
Type number : OfficePrinterUsageBlackMarker [ commandTopic="openHab/Office/Printer/UsageBlackMarker", retained=true, postCommand=true ]
Type number : OfficePrinterUsageColorMarker [ commandTopic="openHab/Office/Printer/UsageColorMarker", retained=true, postCommand=true ]
Type number : OfficePrinterInkColorLevel [ commandTopic="openHab/Office/Printer/InkColorLevel", retained=true, postCommand=true ]
Type number : OfficePrinterUsageTotalColorCount [ commandTopic="openHab/Office/Printer/UsageTotalColorCount", retained=true, postCommand=true ]
Type number : OfficePrinterUsageTotalMonochromeCount [ commandTopic="openHab/Office/Printer/UsageTotalMonochromeCount", retained=true, postCommand=true ]
Type number : OfficePrinterUsageJamEvents [ commandTopic="openHab/Office/Printer/UsageJamEvents", retained=true, postCommand=true ]
Type number : OfficePrinterUsageMispickEvents [ commandTopic="openHab/Office/Printer/UsageMispickEvents", retained=true, postCommand=true ]
Type number : OfficePrinterUsageSubsciptionCount [ commandTopic="openHab/Office/Printer/UsageSubsciptionCount", retained=true, postCommand=true ]
//Network
//Marcel Handy
Type switch : MarcelHandyOnline [ commandTopic="openHab/Network/MarcelHandy/Online", retained=true, postCommand=true, on="true", off="false" ]
Type number : MarcelHandyLatency [ commandTopic="openHab/Network/MarcelHandy/Latency", retained=true , postCommand=true ]
The actual channels from the things look like these:
Switch MarcelHandyOnline "Online" {channel="network:pingdevice:192_168_0_26:online", channel="mqtt:topic:Tc3:Connection:MarcelHandyOnline" [profile="follow"]}
Number:Time MarcelHandyLatency "Latency" {channel="network:pingdevice:192_168_0_26:latency", channel="mqtt:topic:Tc3:Connection:MarcelHandyLatency"}
With the profile: follow by the Switch item I am able to forward the information via MQTT as excpected. But if I add the profile to the number item I will get an exception:
2020-02-09 13:46:11.183 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.mqtt.generic.internal.handler.GenericMQTTThingHandler@f46152': null
java.lang.NumberFormatException: null
at java.math.BigDecimal.<init>(BigDecimal.java:497) ~[?:1.8.0_232]
at java.math.BigDecimal.<init>(BigDecimal.java:383) ~[?:1.8.0_232]
at java.math.BigDecimal.<init>(BigDecimal.java:809) ~[?:1.8.0_232]
at org.openhab.binding.mqtt.generic.values.NumberValue.update(NumberValue.java:106) ~[?:?]
at org.openhab.binding.mqtt.generic.ChannelState.publishValue(ChannelState.java:333) ~[?:?]
at org.openhab.binding.mqtt.generic.AbstractMQTTThingHandler.handleCommand(AbstractMQTTThingHandler.java:128) ~[?:?]
at sun.reflect.GeneratedMethodAccessor215.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_232]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_232]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy54119.handleCommand(Unknown Source) [?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:74) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemFollowProfile.onStateUpdateFromItem(SystemFollowProfile.java:60) [bundleFile:?]
at sun.reflect.GeneratedMethodAccessor212.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
So alle number items want get published at all. I could go with the work arround and create rules for every item, but that is not the right way and would take to much time.
I appreciate all your help.
Marcel
