I get some strange errors during startup of my openhab system…
Can you please give me some advice what is wrong?
this is my jdbc.cfg file
############################ JDBC Persistence Service ##################################
# I N S T A L L J D B C P E R S I S T E N C E S E R V I C E
# https://github.com/openhab/openhab/wiki/JDBC-Persistence
# Tested databases/url-prefix: jdbc:derby, jdbc:h2, jdbc:hsqldb, jdbc:mariadb, jdbc:mysql, jdbc:postgresql, jdbc:sqlite
# derby, h2, hsqldb, sqlite can be embedded,
# If no database is available it will be created, for example the url 'jdbc:h2:./testH2' creates a new DB in OpenHab Folder.
# Create new database, for example on a MySQL-Server use:
# CREATE DATABASE 'yourDB' CHARACTER SET utf8 COLLATE utf8_general_ci;
# D A T A B A S E C O N F I G
# Some URL-Examples, 'service' identifies and activates internally the correct jdbc driver.
# required database url like 'jdbc:<service>:<host>[:<port>;<attributes>]'
# url=jdbc:derby:./testDerby;create=true
# url=jdbc:h2:./testH2
# url=jdbc:hsqldb:./testHsqlDb
# url=jdbc:mariadb://192.168.0.1:3306/testMariadb
# url=jdbc:mysql://192.168.0.1:3306/testMysql
# url=jdbc:postgresql://192.168.0.1:5432/testPostgresql
# url=jdbc:sqlite:./testSqlite.db
url=jdbc:mysql://localhost/openhabian
# required database user
user=******
# required database password
password=******
# E R R O R H A N D L I N G
# optional when Service is deactivated (optional, default: 0 -> ignore)
#errReconnectThreshold=
# I T E M O P E R A T I O N S
# optional tweaking SQL datatypes
# see: https://mybatis.github.io/mybatis-3/apidocs/reference/org/apache/ibatis/type/JdbcType.html
# see: http://www.h2database.com/html/datatypes.html
# see: http://www.postgresql.org/docs/9.3/static/datatype.html
# defaults:
#sqltype.CALL = VARCHAR(200)
#sqltype.COLOR = VARCHAR(70)
#sqltype.CONTACT = VARCHAR(6)
#sqltype.DATETIME = DATETIME
#sqltype.DIMMER = TINYINT
#sqltype.LOCATION = VARCHAR(30)
#sqltype.NUMBER = DOUBLE
#sqltype.ROLLERSHUTTER = TINYINT
sqltype.STRING = VARCHAR(65500)
#sqltype.SWITCH = VARCHAR(6)
# For Itemtype "Number" default decimal digit count (optional, default: 3)
#numberDecimalcount=
# T A B L E O P E R A T I O N S
# Tablename Prefix String (optional, default: "item")
# for Migration from MYSQL-Bundle set to 'Item'.
#tableNamePrefix=Item
# Tablename Prefix generation, using Item real names or "item" (optional, default: false -> "item")
# If true, 'tableNamePrefix' is ignored.
#tableUseRealItemNames=
# Tablename Suffix length (optional, default: 4 -> 0001-9999)
# for Migration from MYSQL-Bundle set to 0.
#tableIdDigitCount=
# Rename existing Tables using tableUseRealItemNames and tableIdDigitCount (optional, default: false)
# USE WITH CARE! Deactivate after Renaming is done!
#rebuildTableNames=true
# D A T A B A S E C O N N E C T I O N S
# Some embeded Databases can handle only one Connection (optional, default: configured per database in packet org.openhab.persistence.jdbc.db.* )
# see: https://github.com/brettwooldridge/HikariCP/issues/256
# jdbc.maximumPoolSize = 1
# jdbc.minimumIdle = 1
# T I M E K E E P I N G
# (optional, default: false)
#enableLogTime=true
my addons.cgf file
persistence = jdbc-mysql
my jdbc.persist file
// persistence strategies have a name and a definition and are referred to in the "Items" section
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
*: strategy = everyDay, restoreOnStartup
group_house_sumenergy* : strategy = everyMinute, restoreOnStartup
group_house_doorwindow* : strategy = everyMinute, restoreOnStartup
group_climate* : strategy = everyMinute, restoreOnStartup
group_house_totalenergy* : strategy = everyChange, restoreOnStartup
group_house_actualpower* : strategy = everyChange, restoreOnStartup
group_house_temperature* : strategy = everyMinute, restoreOnStartup
group_house_humidity* : strategy = everyMinute, restoreOnStartup
number_groupclimatechartperiod : strategy = everyMinute, restoreOnStartup
number_groupenergychartperiod : strategy = everyMinute, restoreOnStartup
and the error occurs on startup are
2020-08-24 21:07:06.344 [ERROR] [org.openhab.persistence.jdbc ] - bundle org.openhab.persistence.jdbc:1.14.0 (285)[org.openhab.persistence.jdbc(330)] : The activate method has thrown an exception
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:129) ~[?:?]
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:97) ~[?:?]
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:89) ~[?:?]
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:63) ~[?:?]
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:73) ~[?:?]
my database is
utf8mb4_general_ci
